#208640 - 09/03/2004 22:13 Serial Commands from Telnet?
SonicSnoop
Loc: Triangle, VA
Is it possible to somehow pass serial commands to the player from a telnet session or bash script? I tried searching for this but couldnt find it.. If I missed it please point me to it Thanks!
#208641 - 10/03/2004 07:37 Re: Serial Commands from Telnet? [Re: SonicSnoop]
cushman
Loc: Erie, CO
echo "n" > /proc/empeg_notify
(skips to next song)
Mark Cushman
#208642 - 10/03/2004 08:05 Re: Serial Commands from Telnet? [Re: SonicSnoop]
For more commands you can send using the mechanism Mark describes above, clicky clicky. List may be slightly incomplete or outdated, but most of them should work.
#208643 - 10/03/2004 12:44 Re: Serial Commands from Telnet? [Re: cushman]
SonicSnoop
Loc: Triangle, VA
Thanks for the reply. I thought that should be it, But I keep trying and no command will work for me that way. Really I just need a way to change the volume up and down one notch from a bash script. and I tried " echo "x" > /proc/empeg_notify and I tried + in place of x nothing, also tried " " for play, and "n" for next track same. I have notify=1 in my config.ini .. I can do the whole popup 3 message and it works. Anyone have any ideas? Thanks
#208644 - 10/03/2004 16:03 Re: Serial Commands from Telnet? [Re: SonicSnoop]
echo "button=VolUp" >/proc/empeg_notify
#208645 - 11/03/2004 06:21 Re: Serial Commands from Telnet? [Re: mlord]
SonicSnoop
Loc: Triangle, VA
Thank you, I will give that a shot later, but considering you compiled this kernel im sure it works
#208646 - 11/03/2004 16:05 Re: Serial Commands from Telnet? [Re: mlord]
SonicSnoop
Loc: Triangle, VA
Works great! Thanks! Is there any way I can also cancel the popup message for volume when I issue that? not for all volume changes just from the console.. Thanks
#208647 - 11/03/2004 17:13 Re: Serial Commands from Telnet? [Re: SonicSnoop]
I don't know of a way to prevent the volume popup.
#208648 - 11/03/2004 17:36 Re: Serial Commands from Telnet? [Re: mlord]
SonicSnoop
Loc: Triangle, VA
ok Thanks
