#209222 - 14/03/2004 06:25 Kamikaze Karma
Well just to add to my list of woes since I got Karma'd the little bugger just jumped out of my hand onto the pavement, the power switch doesn't work any more and the RioStick's a bit iffy Is it bad to send it back to Amazon?
#209223 - 14/03/2004 15:49 Re: Kamikaze Karma [Re: tahir]
brendanhoar
I have a similar q: mine seems to be defective as I'm getting heavy buzzing on the left channel.
Considering I threw away the plastic container, but that I kept all the paperwork (and most of the cardboard) and it's been < 30 days, will I have better luck exchanging it via Amazon, or RMAing it?
EDIT: crap, I bought it from another online merchant. Anyway, for the general case, if I bought it online, and it's defective, is return/replace via the merchant a better way to go than RMA?
-brendan
#209224 - 14/03/2004 18:40 Re: Kamikaze Karma [Re: brendanhoar]
When mine died and was less than 30 days old Rio told me I had to exchange it. I got mine from Amazon and they were very nice about exchanging it. They sent me the replacement first and a prepaid return label (which I didn't use).
#209225 - 15/03/2004 12:25 Re: Kamikaze Karma [Re: tahir]
If you've physically damaged the unit (and it's obvious) I suspect that the vendor isn't going to buy the explaination that it beat itself up. Warranties don't cover dropping things - that's the job of insurance
#209226 - 15/03/2004 12:38 Re: Kamikaze Karma [Re: altman]
I'd say it's fairly obvious, so my first ever insurance claim coming up. Before I do, is it worth taking it apart? The power button doesn't work and some of the RioStick functions are messed up, I have to push right to pause. The case isn't cracked or anything just a couple of digs in it.
#209227 - 15/03/2004 12:49 Re: Kamikaze Karma [Re: tahir]
The controls are probably surface-mount soldered, so the loose volume knob means it's detached from the circuit board and is just dangling around bumping into random stuff.. not good -- could short circuit something else and really fry things.
#209228 - 16/03/2004 13:33 Re: Kamikaze Karma [Re: tahir]
It might not be that bad to fix, I've not seen a joystick that's come off the PCB yet.
Personally, I'd take it apart but be very careful when taking the main board out of the front side of the case - it's incredibly easy to break the hold switch when doing this. Oh, and you need to pull the front glass off the unit after removing the handle, as there's a screw under here that holds the top right quarter of the player on.
YMMV, obviously!
#209229 - 17/03/2004 05:01 Re: Kamikaze Karma [Re: altman]
Thanks for that Hugo, I might try it as my insurance excess is £ 250.00 and I only paid £ 270.00 for the Karma. By the way what does YMMV mean?
#209230 - 17/03/2004 05:04 Re: Kamikaze Karma [Re: tahir]
Your Mileage May Vary
#209231 - 17/03/2004 05:10 Re: Kamikaze Karma [Re: andy]
Thanks Andy
#209232 - 21/03/2004 02:50 Re: Kamikaze Karma [Re: altman]
OK I took it apart Friday night, the power switch has come off the PCB, I fixed it back on with superglue which worked except the switch is now jammed solid, does anyone know where I can get a replacement?
#209233 - 23/03/2004 04:23 Re: Kamikaze Karma [Re: tahir]
Anybody? If I can't find another power switch then it's pretty much useless to me so if anyone in the UK wants it for spares PM me and I'll mail it to you.
#209234 - 23/03/2004 15:38 Re: Kamikaze Karma [Re: tahir]
You have a PM....
#209235 - 29/03/2004 00:47 Re: Kamikaze Karma [Re: tahir]
If you send it to me in Cambridge, I can probably fix it. There are enough early Karma PCBs around for me to nab some parts off...
#209236 - 07/04/2004 07:36 Re: Kamikaze Karma [Re: altman]
Thanks Hugo it's back in action
#209237 - 07/04/2004 10:21 Re: Kamikaze Karma [Re: tahir]
Hugo is da man.
#209238 - 07/04/2004 10:54 Re: Kamikaze Karma [Re: tfabris]
Hugo is da man.
Not half
