#210922 - 24/03/2004 21:08 Riocar HardDisk Upgrade
utna
Loc: LA, CA
Well, i violated my warranty today
I bought a new hard drive, a travelstar 40 Gb. I put it in, and used the drivebuilder, then put the dev 2.00 on it. then i did the same for the original drive.
Then i put the jumper on and slaved the 40 Gb to the master 20Gb. However, now empeg crashes.
Anyway, I'm trying to get the HD to work together to no avail.
emplode keeps crashing
empeg-car bootstrap v1.02 20001106 ([email protected])5 > hda2 hda3 hda4 CS4231A revision a0
If there is anyone present who wants to upgrade the flash, let them speak now,mpeg
or forever hold their peace...it seems not. Let fly the Penguins of Linux!itialised, PDIUSBD12 logo.
Probing
e000 v1.04rface...
Copying kernel...
hda: IC2
Calling linux kernel...drived 0089/88c1 (save
hda: IC25N040ATCS04-0, ATA DISK drive
empe
l.DS
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315ic driver initialised
(release)) #11 Tue Apr 1 18:49:59 BST 2003SK drivesk driver initialized: 16 RAM dis
smc chip id/revision 0x3349
Dentry hash table entries: 2048 (order 2, 16k)check:k Stahlman (erik
SMC9194: SMC91
Page cache hash table entries: 4096 (order 2, 16k)044b MAC 00:02:d7:26:09:3
Linux NET4.0 for Linux 2.2e.
Based upon Swansea Universit
5
Partition
Starting kswapd v 1.5
0
SA1100 serial driver version 4.27 with no serial options enabledmounted
dev 03:44 blksize=1024
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTnt=1
mke2fs
Filesystem label=Por
empeg dsp mixer initialised
empeg dsp initialised4 (log=0)
empeg audio-in initialised, CS4231A revision a0ul 24 2002
81
empeg remote control/panel button initialised.6d000
64 inodes per groupk/16M available (
empeg state support initialised 0089/88c1 (save to d0004080).ored on blocks:init)
empeg RDS driver initialised57345, 73729, 204801, 221185
RAM disk driver initialized: 16 RAM
NET4: Linux T
hdstress.cpp
hda: IC=Nzwqmvss04-0, ATA DISK drive
hda: IC=Nzwqmvss04-0, ATA DISK drivenning down.ision:Tue May 18 03:11:39
hd
hda: IC=Nzwqmvss04-0, ATA DISK drive0 on fd=5
ide0 at 0x000-0x007,0x038 on irq 6irtual tty driver for
hda: IC=Nzwqmvss04-0, 57231MB w/2042kB Cache, CHS=7295/255/63 )
hdstress.cpp 1
empeg-flash driver initialized=5
smc chip id/revision 0x3349ng kswapd v 1.5
Scheduli
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
19:03:40.718 protocolclient.cpp(1278) : I [0394] ProtocolClient::SendCommand()=0
19:03:40.718 protocolclient.cpp(1351) : I [0394] Restart command sent, waiting for player to begin responding
19:03:42.218 protocolclient.cpp(992) : I [0394] ProtocolClient::WaitForUnitConnected(timeout=90)
19:03:43.140 connection_win32.cpp(1058) : W [0394] connect() failed: 10061
19:03:43.140 packets.cpp(77) : I [0394] NEW request, id=0x808080cb
19:03:44.140 connection_win32.cpp(1058) : W [0394] connect() failed: 10061
19:03:44.640 connection_win32.cpp(1063) : I [0394] Created connection to '192.168.2.7' (0x702a8c0)
19:03:44.640 connection_win32.cpp(1000) : D [0394] Select timed out (0ms)
19:03:44.640 protocolclient.cpp(1041) : I [0394] ProtocolClient::WaitForUnitConnected()=0
19:03:44.640 protocolclient.cpp(1366) : I [0394] ProtocolClient::InternalRestart()=0
19:03:44.640 database_fetcher.cpp(159) : E [0394] CheckPlayerDatabase failed, status = 0xc0041016
19:03:44.640 DatabaseOperation.cpp(109) : I [0394] DatabaseOperation::CloseConnection
any suggestions?
riocar Mk2A 030102357 - 60 Gb
#210923 - 24/03/2004 21:20 Re: Riocar HardDisk Upgrade [Re: utna]
SE_Sport_Driver
Press 'q' now to go into development ...
Are you sure that the connections are secure? Not off by 1 pin? Put the master at the end of the cable...
PS - Your warranty expired long ago.
Edited by SE_Sport_Driver (24/03/2004 21:21)
#210924 - 24/03/2004 21:26 Re: Riocar HardDisk Upgrade [Re: utna]
utna
Loc: LA, CA
looks like the jumper pin was intermitent. thanks
empeg-car bootstrap v1.02 20001106 ([email protected])M:6144b MAC 00:02:d7:26:09:3
hda: hda1 < hda5 > hda2 hda3 hda4
hdstress.cpp 1
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.p
e000 v1.0429): Poll
Copying kernel...
Calling linux kernel...time reached, running e
hdstress.cpp 189 ( 29): Poll result=0 on fd=5
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315rive
hdstress.cpp 189 (
Processor: Intel StrongARM-1100 revision 11pinning down.
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)stress.cpp 189 ( 29): Poll result=0 on fd=5
hda:
Speed checking /dev/hda
Buffer cache hash table entries: 16384 (order 4, 64k)pp 189 ( 29): Poll result=0 on fd=5filesystem fou
Read/write
POSIX conformance testing by UNIFIX[1 disk] into ram disk.
Based upon Swansea Universit29)
Seek test complete: 37.83
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )lt=0 on fd=5
Stressing /dev/hd
Stressing /dev/hda: S
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTess.cpp 189 ( 29): Poll result=0 on fd=5
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTtress.cpp 189 ( 29): Poll result=0 on fd
empeg display initialised.
hdstress.cpp 189 (
empeg dsp audio initialised5
empeg dsp mixer initialisedress.cpp 189 ( 29): Pol
empeg audio-in initialised, CS4231A revision a03
hdstress.cpp 189 (
Read/write of 8
empeg state support initialised 0089/88c1 (save to d0004100).
Stressing /dev/hda: Spinning down.
empeg RDS driver initialisedcpp 189 ( 29): Poll resu
Stressing /dev/hda: Spinning up.
ide0 at 0x000-0x007,0x038 on irq 6024 (log=0)
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
2375
hda: IC=Nzwqmvss04-
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
empeg-flash driver initializedDISK drive
smc chip id/revision 0x3349per group
hda: IC
Mounting proc
Starting player
Vcb: 0x4086d000
#210925 - 24/03/2004 21:45 Re: Riocar HardDisk Upgrade [Re: utna]
SE_Sport_Driver
I have a peice of tape over mine because I used a jumper for a 3.5" drive ... Good idea anyway in case it ever shakes off.
So it works now? (congrats on the upgrade btw)
#210926 - 26/03/2004 13:23 Re: Riocar HardDisk Upgrade [Re: SE_Sport_Driver]
utna
Loc: LA, CA
yes, it works gret.
i soldered it. it's not going to argue any more.
#210927 - 26/03/2004 19:47 Re: Riocar HardDisk Upgrade [Re: utna]
utna
Loc: LA, CA
I was actually thinking along these lines when i mentioned Voiding the warranty.
