#211044 - 25/03/2004 17:30 CharcoalGray99 Web Interface with only Playlists..
SE_Sport_Driver
As Mark Lord mentioned in this post, it would be possible to hack the Charcoalgrey web interface to ONLY show the playlists (and maybe keep harmless stuff like Web Links and the empeg logo) but remove the Remote, Display, FTP, Commands, Download, Stream and Insert links/buttons. I'd like to be able to show my playlists to someone online so that they could make requests during my show, but I don't want them to have full rein of my empeg.... I tried hacking that stuff out last night, but I'm not good enough with XML to know what I'm doing. Get beyond Notepad and basic HTML and I'm lost!
I havnt heard back from CharcoalGray, so I thought I'd ask here..
#211045 - 30/03/2004 23:50 Re: CharcoalGray99 Web Interface with only Playlis [Re: SE_Sport_Driver]
bodybag
Loc: Southern California
I'd like to have something like this too, but I would retain only the stream option and get rid of the other stuff. I use my Empeg at work and many of my co-workers have realized they can stream from my Empeg but I'm affraid that someone is going to F something up. Most often, someone who doesn;t know any better sees something they'd like to hear and clicks play instead of stream.
Bodybag - So Cal
Not a Whiner any more!!!
#211046 - 02/04/2004 18:16 Re: CharcoalGray99 Web Interface with only Playlists.. [Re: SE_Sport_Driver]
SE_Sport_Driver
"crossing my fingers"
tman ijs working on something using SQL, php and the export to csv feature of emplode to do what I'm looking for..... woohoo!
#211047 - 03/04/2004 07:44 Re: CharcoalGray99 Web Interface with only Playlis [Re: SE_Sport_Driver]
Keep in mind, that if one really wants to disable EVERYTHING except streaming, then this functionality is already built-into Hijack and the web interfaces.
#211048 - 04/04/2004 17:04 Re: CharcoalGray99 Web Interface with only Playlis [Re: mlord]
SE_Sport_Driver
I agree, that sounds like the best thing for bodybag..
#211049 - 06/04/2004 14:38 Re: CharcoalGray99 Web Interface with only Playlis [Re: mlord]
bodybag
I didn't see this anywhere in the Hijack menu if it's built-in? Also, I don't see anything in Charcoalgray's webinterface that I'm using that would allow me to disable all but the streaming. Is this something that is not a menu item in Hijack or the webinterface that needs to be controlled via a shell prompt?
Bodybag - So Cal
#211050 - 06/04/2004 15:49 Re: CharcoalGray99 Web Interface with only Playlis [Re: bodybag]
To access the Hijack web interface without CharcoalGray's stuff, use this URL:
http://empeg_address/?fid=101&ext=.html
To prevent users from chaning things on the player, you do not use the Hijack menu, you use config.ini. Complete details of all the config.ini options are in the Hijack section of the FAQ.
You might want to start with options similar to this, and look through the FAQ for more:
[hijack]
disable_emplode=1
max_connections=????
kftpd_control_port=0
khttpd_port=80
khttpd_dirs=0
khttpd_commands=0
#211051 - 09/04/2004 16:17 Re: CharcoalGray99 Web Interface with only Playlis [Re: mlord]
SE_Sport_Driver
Hey check this out . tman put this together...
#211052 - 11/04/2004 15:44 Re: CharcoalGray99 Web Interface with only Playlis [Re: SE_Sport_Driver]
bodybag
how do I get it?
Bodybag - So Cal
#211053 - 12/04/2004 15:39 Re: CharcoalGray99 Web Interface with only Playlis [Re: bodybag]
SE_Sport_Driver
I'm trying to get tman to not be shy and post it.
#211054 - 14/04/2004 18:06 Re: CharcoalGray99 Web Interface with only Playlis [Re: bodybag]
SE_Sport_Driver
Posted in this thread.
