Page 4 of 4 < 1 2 3 4
#213117 - 31/05/2004 07:28 Re:EMSC, Improved response to remotes [Re: jules]
rtundo
Loc: Albany, NY
Jules, thanks for the update and the expanation of setting the rates. I'll give it a shot this week, and I'll let you know what happens. Other than button press problems, I've enjoyed your program a lot (No problems have popped up). Also, just curious how (if) things are progressing on moving the song database to the computer.
#213118 - 04/11/2004 12:30 Re:EMSC, Improved response to remotes [Re: rtundo]
iopcool25
Loc: New York
hey jules cool program just wanted to know if the computer you have running xp in your car are you running all your audio from the computer or from the empeg and if its from the empeg can your run movies files from the computer and see them on a screen and hear it through the car speakers. Basically is it possible to run both empeg and computer audio on only the empegs audio connections
#213119 - 04/11/2004 16:45 Re:EMSC, Improved response to remotes [Re: iopcool25]
mtempsch
You can use an RCA switch (controlled by one of the units remote turn on wire) to have two sources hooked up to a single amp. Whenever the one designated as master is active it is switched through to the amp.
#213120 - 05/11/2004 02:06 Re:EMSC, Improved response to remotes [Re: mtempsch]
iopcool25
Loc: New York
good reply but (to Jules) if you have a computer hooked up to the empeg in your car (maybe) and u wanted to watch a video how would you hook up the audio (question to jules)
