#213579 - 18/04/2004 13:53 Empeg streaming mp3s and WMP
SonicSnoop
Loc: Triangle, VA
I pretty much know this isnt a empeg issue but thought Id ask and see if someone could help me figure out whats wrong. At home I can click to stream an entire playlist and it lists every song in WMP and pulls the track titles and everything. Works great there, However at work I do the same thing and I only get a single track listed called playlist# and no track titles nothing just the empeg ip address.. Anyone know what settings may be wrong in WMP/How I can correct this at work? Thanks!
#213580 - 18/04/2004 14:37 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
SE_Sport_Driver
Have you tried Winamp to see if it's a software issue or something else?
#213581 - 18/04/2004 18:21 Re: Empeg streaming mp3s and WMP [Re: SE_Sport_Driver]
SonicSnoop
Loc: Triangle, VA
No I dont have winamp at work. The empeg works fine at home, but soon as i walk into work, flip to work mode and stream i get the above. I could try and attempt a winamp install tomorrow.
#213582 - 18/04/2004 21:13 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
So.. what's different in config.ini for ;@WORK mode.. ?
Post the file for us.
#213583 - 19/04/2004 03:23 Re: Empeg streaming mp3s and WMP [Re: mlord]
SonicSnoop
Loc: Triangle, VA
The things for @Work in my config.ini are:
[Network]
;@Work DHCP=1
[hijack]
;@Work kftpd_control_port=0
;@Work khttpd_port=666
;@Work khttpd_basic=user1:pass1
;@Work khttpd_full=user2:pass2
After typing this in I went to double check if it was work mode cause I can use work mode at home cause my router has dhcp abilities. It wasnt that. it was fine, I was having a major blonde moment, I use winamp at home not WMP (Doh!) WMP doesnt work at home either, Ill install winamp at work and it will probobly be fine.
#213584 - 19/04/2004 07:25 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
Okay, good.
Also ensure you have the latest Hijack (v383), since there have been a couple of bug fixes to the original HTTP authentication stuff.
#213585 - 19/04/2004 12:34 Re: Empeg streaming mp3s and WMP [Re: mlord]
SonicSnoop
Loc: Triangle, VA
Yeah I have the 838. Your just too fast with it.. When I read your 831 thread you already had 838 out. Thanks for the help.
#213586 - 19/04/2004 13:37 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
RobotCaleb
38*
#213587 - 20/04/2004 04:37 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
SonicSnoop
Loc: Triangle, VA
Opps I ment 833
#213588 - 20/04/2004 15:02 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
RobotCaleb
ok, now im just confused
#213589 - 20/04/2004 17:55 Re: Empeg streaming mp3s and WMP [Re: SonicSnoop]
SonicSnoop
Loc: Triangle, VA
Never mind ignore me LOL I cant get the frigging version number right to save my self.. LOL I must be having a dislexic week or something... Im not even gonna try again
