#214303 - 24/04/2004 20:23
Swapping MkIIa board into MkII case
Is there any reason i couldn't put a MkIIa motherboard into a MkII case, keeping the original MkII screen and harnesses? Since i've got 70GB on my MKII, the drives are ALWAYS spun up and it's overheating regularly on trips of half an hour or more. It needs more RAM. And until the extra RAM hack is worked out, i need a quick fix.
Pretty sure i know the answer to this, but just wanna make sure before i do it.
#214304 - 24/04/2004 20:44
Re: Swapping MkIIa board into MkII case
[Re: loren]
Okay. Obvious question here but couldn't you just move the drives over instead?
#214305 - 24/04/2004 23:31
[Re: tman]
Okay. Obvious question here but couldn't you just move the drives over instead? I believe he also wants the display board assembly from the 2A because it's got the newer type of rotary encoder.
What you want to do, Loren, is do-able I think. The display boards are meant to be interchangeable. My only problem is... I don't think the extra RAM is going to make a difference in the temperature. There's not going to be a huge difference in spin-up times. It will only be slight, not enough to make a thermal difference.
I think it might be time for the big step. Go see if WeirdStuff still has that big styrofoam crate full of tiny fans.
#214306 - 25/04/2004 11:42
No. He wants to keep the old display and stuff, for whatever reason. And it's not going to affect the spinup, but, rather, keep the drive from spinning all the time by increasing the amount of cache available.
#214307 - 25/04/2004 11:51
Here's why i think it will make a difference: The same drive configuration, two 40 gb drives, has been in the WRX since i installed the empeg, no change there. I did get overheating, but once i drilled vent holes into the pocket above the empeg, no more overheating. It's been fine for months that way with daily use. Then last week i uploaded another 30 gigs or so that i'd been retagging and now the drives are literally ALWAYS spun up according to the disk activity icon. So after half an hour it gets overheated. The drives being spun down at all seemed to help.
And as for why i don't just use the MkIIa... the way i have my sled installed, i can't even fit a MkIIa into it. It's bolted in from the side and is one of the coated black sleds. Despite the size of the empegs supposedly being exactly the same, i can tell you from experience they definitely are not. My MkII slides in fine with plenty of room, but the MkIIa won't go pas the first sled nipple... which can't be bent out due to the mounting bracket in the WRX. Should be an easy swap so i'll give it a try before i venture into fan world. Unless i have one... *me goes digging in my junk computer box*
Thanks!
#214308 - 25/04/2004 12:06
[Re: loren]
To be honest, I am kind of curious why the drives are not spinning down. Do you have that disabled through hijack? Have you uploaded different filetypes (flac)? Adding more music should not change drive behavior like that.
#214309 - 25/04/2004 12:09
[Re: pgrzelak]
Wish i knew. I haven't disabled it, and i'm still running good old VBR MP3s. I just figured the database was taking up all the RAM. I'm still running 2.0Final
#214310 - 25/04/2004 12:49
[Re: loren]
Hmmm... Something sounds a bit strange. Try manually fsck-ing the drives. Also, try going into your config.ini and verify your settings. See what kind of memory reserve you have, any applications that are loaded that may be logging or keeping the drives spinning. I would almost recommend backing up your existing config.ini and putting a clean one in its place (not loading any additional software or memory tweaks) just to see if it makes a difference. Also try inserting a forced spindown time to see if it changes things.
#214311 - 25/04/2004 13:16
[Re: pgrzelak]
Doing all of the above now...
#214312 - 25/04/2004 13:44
[Re: loren]
Definitely nothing weird in the config.ini:
[hijack]
khttpd_root_index=/drive0/opt/khttpd/charcoalgray99/index.html
[output]
notify=1
[hush]
hushpercent=20
[display]
play_count=1
visual_names=1
caching=1
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=0
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=emp3g
[User Info]
Email=loren@*******.com
Phone=415-*******
Name=Loren Cox
[Network]
;@HOME DHCP=0
;@WORK DHCP=1
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.20
DHCP=0
[sense]
muteaction=1
mute=1
[power]
off_timeout=60000
[aux]
source=
title=
artist=
[synchronise]
seq_num=88
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[shuffle]
deduplicate=0
Running fsck...
#214313 - 25/04/2004 13:49
[Re: loren]
K.... seems that i've found something. I plugged er up to the serial and i'm getting this message after reboot:
Vcb: 0x4058a000
spindown_chunk_cache_runner.cpp: 294:Filling up space (-12)
spindown_chunk_cache_runner.cpp: 294:Filling up space (-15)
.....ad nauseum....
any ideas?
a quick search shows Roger saying these aren't anything important. Running fsck now.
#214314 - 25/04/2004 14:06
[Re: loren]
a quick search shows Roger saying these aren't anything important. Yeah, except your numbers are negative. In other words, the cache is telling you something you already know: the database is taking up so much memory that there isn't enough cache left ever to spin down.
Out of interest, how big is your database file ( ls -l /empeg/var)?
#214315 - 25/04/2004 14:21
[Re: peter]
I'll check as soon as this fsck is over... could be a while... or is it okay to interupt an fsck?
edit: okay, fsck done, with this result on the first drive:
/dev/hda4: 18643/304448 files (23.3% non-contiguous), 30281113/38965657 blocks
and ls -l /empeg/var results in:
lrwxrwxrwx 1 0 220 13 Apr 1 2003 /empeg/var -> ../drive0/var
#214316 - 25/04/2004 14:31
[Re: loren]
ls -al /drive0/var
#214317 - 25/04/2004 14:35
[Re: pgrzelak]
empeg:/empeg/bin# ls -al /drive0/var
ls: /drive0/var: No such file or directory
looks like it needs to be rebuilt eh?
Edited by loren (25/04/2004 14:38)
#214318 - 25/04/2004 14:38
[Re: loren]
Huh???
Okay... that is weird... Oh, did you unmount the drives to fsck them? Try first doing "rom" and "ro". Reboot. Go back to shell. "ls -al /drive0/var"...
#214319 - 25/04/2004 14:40
[Re: pgrzelak]
Yeah, just realized i gotta finish the fsck first =] brb...
#214320 - 25/04/2004 14:45
[Re: loren]
So you know, what I (and probably Roger also) am looking for is something that looks abnormal with one of your database files. Something that would distort the player application and make the database image in memory so large that it could not possibly spin down the drives.
For reference, on my player (with lots and lots of FIDS), my files are:
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin#
total 4255
drwxr-xr-x 2 root root 1024 Feb 12 10:58 .
drwxr-xr-x 6 root root 1024 Feb 4 10:45 ..
-rw------- 1 root root 1594 Dec 21 14:16 config.ini
-rw-rw-r-- 1 root root 4201145 Feb 12 10:57 database
-rw-rw-r-- 1 root root 131836 Feb 12 10:58 playlists
-rw-rw-r-- 1 root root 376 Feb 12 10:57 tags
empeg:/empeg/bin#
Granted, yours will not be the exact same size, but if they look significantly bigger, or the directory structure looks different, you may want to try to manually rebuild the databases.
#214321 - 25/04/2004 14:50
[Re: peter]
Loc: East Coast, USA
Hm...... a database of 70gigs of music is filling the MKII ram, but Paul's database of 160gig isn't filling the MKIIa ram? So that few meg ram difference DOES matter? Or are Paul's drives spun up all the time? And is his player overheating because of it?
And to reply to an earlier post in the thread re: flac and alternative file types: Would it keep the drives spun up to play FLAC or WAV? I'm assuming yes because it's a bit hard to cache an 80 meg song in 16 meg ram.
#214322 - 25/04/2004 15:03
[Re: FireFox31]
Well, that is the suspected cause. Still unproven. Just a theory.
The memory does help quite a bit.
Not that I know of, on both counts.
Exactly. Since you need more data per second, you cannot effectively cache that kind of file as easily. Or perhaps, you can cache it, but you burn through it so quickly that it really doesn't help.
#214323 - 25/04/2004 15:12
[Re: loren]
empeg:/empeg/bin# ls -lah /drive0/var
total 3.1M
drwxr-xr-x 3 0 0 1.0k Jul 2 04:41 .
drwxr-xr-x 6 0 0 1.0k May 11 2035 ..
-rw-r--r-- 1 0 0 810 Jul 2 04:41 config.ini
-rw-r--r-- 1 0 0 3.0M Jul 2 04:41 database
-rwxr-xr-x 1 0 0 25k Mar 10 2002 date
-rwxr-xr-x 1 0 0 4.4k Mar 10 2002 pcmplay
-rw-r--r-- 1 0 0 75k Jul 2 04:41 playlists
-rwxr-xr-x 1 0 0 3.7k Mar 10 2002 setvol
-rw-r--r-- 1 0 0 417 Jul 2 04:41 tags
drwxr-xr-x 2 0 0 2.0k Mar 10 2002 tts
-rwxr-xr-x 1 0 0 2.5k Mar 10 2002 ttsclock wonder if that old tts stuff is doing it. I can just nuke this whole directory right? It'll all get rebuilt?
#214324 - 25/04/2004 15:19
[Re: loren]
okay... Nothing immediately catches my attention there...
In your config.ini, in the display section, you have caching=1. I am not familiar with that option, and I am looking it up. What does this do?
#214325 - 25/04/2004 15:24
[Re: pgrzelak]
Rebuilding the database after deleting all the TTS stuff.
no idea about the caching=1 thing... don't recall adding that one.
#214326 - 25/04/2004 15:25
[Re: loren]
Loc: US: CA
I believe that just enables the disk activity icon... I think...
#214327 - 25/04/2004 15:25
[Re: loren]
I found it. Basically the option that turns on the display of disk activity...
#214328 - 25/04/2004 15:31
[Re: pgrzelak]
One thought (back to the original subject). If your player is running that hot (granted, with the drives spinning all the time) you may still want to install a cooling fan. Just to be safe.
#214329 - 25/04/2004 15:33
[Re: pgrzelak]
okay... databases have been rebuilt, and both drives fscked.
Rebooted and still getting this:
Vcb: 0x4058a000
Any other ideas?? I'm going to run a ram check...
#214330 - 25/04/2004 15:40
[Re: loren]
Which kernel are you running? Default? Hijack? Custom?
#214331 - 25/04/2004 15:42
[Re: loren]
hijack 363 v2final
Error after ram test:
tplayer(13): memory violation at pc=0x00000000, lr=0x020caf3c (bad address=0x000
00000, code 2)
pc : [<00000000>] lr : [<020caf3c>]
sp : 00000000 ip : bf1ffac0 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : 00000001
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: D036517D Table: D036517D DAC: 00000015
that doesn't look good
#214332 - 25/04/2004 15:49
[Re: loren]
Perhaps a re-flash of the kernel? Other than that, I am at a loss.
