#215032 - 30/04/2004 07:46 Player Hangs at Starting Audio...
Flawed
It's done this before but I don't recall how I fixed it. I was just playing some music that I'd played before so I know it's not a corrupt file or anything and I was messing about in hijack. Basically it looks like I managed to set the source to first aux, nothing is connected there, and then to tuner. Of course I don't have one of those either. Now rebooting it hangs up. Emplode can't see it and I cna't get it to do anything other than respond to hijack commands.
Suggestions?
Boot log forthcoming...
#215033 - 30/04/2004 08:06 Re: Player Hangs at Starting Audio... [Re: Flawed]
The boot log would be good. I suspect (without seeing any data) that you somehow have a corrupt current playlist, and need to start the player with a clean / clear playlist. Instructions here in the FAQ.
#215034 - 30/04/2004 09:10 Re: Player Hangs at Starting Audio... [Re: pgrzelak]
Flawed
Well I was going to post the bootlog but on a whim I decided to simply reflash the kernel with 2 beat 13 and it works now.
I sure won't bitch about that...
Thanks anyway guys!
#215035 - 30/04/2004 10:09 Re: Player Hangs at Starting Audio... [Re: Flawed]
Why 2b13 and not 2.0 final? Just curious.
#215036 - 29/04/2005 05:22 Re: Player Hangs at Starting Audio... [Re: Flawed]
Fogduck
Loc: BC
(wow almost a year to the day I ran into the same problem and found this post in my panic)
OK, another case of hung at "Starting audio..."
Brief history of the evening:
- upgraded to latest Hijack (426)
- downloaded Tony's Face controller tool v1.9 (nice!)
- playing with Face, wondered if I could launch the Hijack menu by clicking and holding over the center of the volume knob
- player hung with source-switch banner at top of display "Source: Player" (I could be wrong, but was something like that)
- flashed power and startup sequence hung at "Starting audio"
- reflashed latest Hijack, no change
- reflashed 2.0b13 kernel, no change
- rebooted in vain a few more times
- fought panic
- found this post
- found the "manually clearing the playlist" tip
- fired up Hyperterminal and rebooted the machine
- and it booted fine BEFORE I COULD INTERVENE
...and here we are.
(been years since my last post, I see a few familiar names here still ... the old guard. Tony: sit tight, you're some CIO's wet dream.)
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
