#216654 - 20/05/2004 20:39 mp3tofid, write failed
ajayrockrock
Loc: Riverside, CA
I just added a 60GB drive bringing my capacity to 100Gigs and I decided to wipe my empeg clean and setup mp3tofid to keep my stuff in check. Everything was going good until I hit about 44% of my 80Gig upload with this error:
[snip]
drive1/fids/_0000f/
write failed on drive0/fids/_00033/b80 : Success
rsync error: error in file IO (code 11) at receiver.c(244)
rsync: connection unexpectedly closed (393191 bytes read so far)
rsync error: error in rsync protocol data stream (code 12) at io.c(150)
+ rom+ swapoff /swapfile
empeg:/#
So /drive0 is my older 40GB drive, does this mean that there's a problem with that drive?
Thanks,
Ajay
#216655 - 21/05/2004 00:03 Re: mp3tofid, write failed [Re: ajayrockrock]
mtempsch
Not sure how mp3tofid and rsync handles it - but might it be that drive0 is simply full? (ie rsync doesn't realise that it should split the contents across two drives)
I'd Ctrl-C out to the shell and take a look...
#216656 - 21/05/2004 02:39 Re: mp3tofid, write failed [Re: ajayrockrock]
skibum
Loc: Swindon, UK
You have to use an option on mp3tofid to tell it to balance the fids across non size matched discs. I've got a 30gb and 20gb and use the following command :-
mp3tofid -Iis2 33 /data/mp3 /data/empeg/christa
The 33 is the part of the split. Although it looks wrong, my player is pretty balanced.
-2: percentage of files on second drive
-s: spread playlists over both drives
#216657 - 21/05/2004 02:48 Re: mp3tofid, write failed [Re: mtempsch]
ajayrockrock
Loc: Riverside, CA
thanks, that was it. I have a 40GB and a 60GB drive so I needed to use the "-2 60" parameter to mp3tofid. That tells it to put 60% of the mp3's on the second drive.
What's the easiest way to check the disk sizes on the empeg? I had to manually create a /etc/mtab file just so I could run 'df'. Is there a better way?
later,
ajay
#216658 - 21/05/2004 02:59 Re: mp3tofid, write failed [Re: ajayrockrock]
df .
That's 'df', followed by a dot. This tells df to ignore /etc/mtab and just check the space on the current drive. So you can use the following as well:
df /drive0
df /drive1
