You could save yourself some money by buying a 2 channel amp and wiring the pairs of speakers in parallel. You would be wiring the speakers as seen on the second diagram on
this page. The left front and rear speakers would be wired in that manner on the left channel, and the same goes for the right.
Be careful, however, as wiring speakers in this manner puts a different load (impedance) on the amplifier, and it will put out more power per channel. Make sure you check the specs for your speakers and the amplifier you are using before doing this.
[Edit:] Originally described series wiring, which was incorrect.
