#217304 - 28/05/2004 16:54 Erratic player
estocks
Loc: Reading UK
Hi
When I put my player in the car I cannot seem to restore my visuals configuration.
Why do the tracks play in different order to how I have set the playlist order using emplode?
Why is the Alpine animated boot logo link dead in new software page.
Urk :-(
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#217305 - 28/05/2004 20:39 Re: Erratic player [Re: estocks]
It's in the FAQ. Short answer, you have to install Hijack to do this. (Unless I misunderstand your problem.)
Are you sure you've changed the true ordering of the playlist, or have you just sorted the tracks in emplode to display in that order (which can be a different order than they're played on the player)?
#217306 - 29/05/2004 10:26 Re: Erratic player [Re: canuckInOR]
Another thing to check about play order is to make sure that Shuffle isn't enabled on the player (if it is, there should be a little 's' next to the "[4/34]"-styled playlist order indicator on the Track info mode. Also make sure that randomize isn't selected in the properties for the playlist. You'll have to use emplode to modify this. It's somewhere in the properties for the playlist.
#217307 - 30/05/2004 09:34 Re: Erratic player [Re: wfaulk]
estocks
Loc: Reading UK
Indeed the random seting was toggled and the playitst is the order one expected.
Thanks for the FAQ tip too.
#217308 - 30/05/2004 10:38 Re: Erratic player [Re: canuckInOR]
Even shorter answer is that you can restore visuals when you're in the car by doing a long press on the down button. That's all Hijack is doing when you enable visuals in the car. You'll only need Hijack if you don't want to have to do it manually.
