#219931 - 03/05/2001 13:51 manual setting of IP Address
schmoelz
Loc: Innsbruck, AUSTRIA
I think it would be a good thing to have the option of manually entering the IP-address and the address of the server, since it will be a problem in many companies/offices to install the Rio Audio Manager as a DHCP Server without permission from the network admin. This would also eliminate problems, when having more than one Audio Manager in the same network.
#219932 - 07/05/2001 10:00 Re: manual setting of IP Address [Re: schmoelz]
This isn't possible - the unit has no writable NVRAM. Actually, it has flash, but the chips used vary between builds and so we never wrote a driver to write to them - the page size (etc) varies a lot between manufacturers.
The ARMGR software does not need to DHCP serve - you just turn off "autoconfiguration on this adaptor" (or something like that). It does local subnet broadcasts to find the music/software server, falling back to all net broadcast if the subnet one fails.
It'll work fine in office environments, we did a lot of testing with this.
#219933 - 08/05/2001 07:46 Re: manual setting of IP Address [Re: altman]
Also, the Manager software DHCP software _only_ serves the Receivers -- it looks for a vendor tag -- and it waits for 3-4 requests before responding, so your office DHCP server should get in there first, anyway.
#219934 - 08/05/2001 08:22 Re: manual setting of IP Address [Re: Roger]
Very clever!
#219935 - 08/05/2001 14:48 Re: manual setting of IP Address [Re: tfabris]
A similar trick of the DHCP is used for the Compaq TaskSmart servers when initially configuring them. Works very well.
