#219991 - 08/05/2001 22:04 Conflicts With Existing Networks?
ReverendPoppy
newbie
I'm a little nervous about setting up my receiver, and a LOT slow about network stuff. So if you answer, please do so it terms an idiot (me) could understand. :)
I'm installing the PCI card in a computer that is already hooked up to a basic peer-to-peer network (no server). This machine is running WinME, the other two are running Win98.
Is this going to cause any problems? Is there anything special I need to look out for during setup?
Thanks.
#219992 - 09/05/2001 12:11 Re: Conflicts With Existing Networks? [Re: ReverendPoppy]
phaigh
I'll let someone post who's actually got one, but there should be no problems with this setup at all.
A common mistake is to think that a PC has an IP address - it doesn't. The interface has an IP address, so each interface will have a different value.
As long as there are no identical IP addresses this should (conceptually) be fine.
If you are installing the PCI card, that means that you are using the HPNA networking stuff, not ethernet (not that this is important, just thought I'd mention it).
Hope this helps.
Paul.
RioReceiver - Still Waiting for one in the UK.
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#219993 - 09/05/2001 13:32 Re: Conflicts With Existing Networks? [Re: ReverendPoppy]
bonzi
If your PC is already on Ethernet, then you don't have to install another network adapter (provided, of course, that your Receiver has Ethernet and not that phone line contraption). You will also have to make sure that your existing adapter runs TCP/IP (as opposed to IPX/SPX and NETsomething - whatever was the name of Microsoft's version of IBM's original PC LAN protocol).
Hm, I am not that sure this helped....
Dragi "Bonzi" Raos
#219994 - 09/05/2001 22:47 Re: Conflicts With Existing Networks? [Re: bonzi]
ReverendPoppy
newbie
Thanks bonzi. Unfortunately, because of where I plan on putting the receivers (home theater, drum room, family room and master bedroom), I'm pretty much forced to use the "phone line contraption". My wife would kill me if I started tearing up walls to run network cables throughout the house!
#219995 - 10/05/2001 08:36 Re: Conflicts With Existing Networks? [Re: phaigh]
Acutally, it can be even more granular than that. Since the IP address is determined by the protocol driver, it's possible to assign multiple protocols (of the same type) to the same interface under Windows. You can have "TCP/IP->MyCard" in the control panel several times, each with different addresses.
