#220342 - 14/10/2001 13:21 Bugette in the Receiver play music list...
nicolgw
The Server imports all 1921 files from its hard disk (this is what it reports when you finish doing the music import) however the Receiver is only listing a small subset of these within the music listings.
Most files on the server are VBR Encoded at High Quality using AudioCatalyst.
A little investigation has shown that 1768 of these files don't have the "Artist" (or any other non-title) field "set" in the ID3 tag, the Receiver doesn't list these under anything such as "", it just ignores them.... meaning that to actually "Play all music" the *only* way to do it is to select "Play all Music" from the title section (as everything has one of those).
Graham
#220343 - 14/10/2001 13:41 Re: Bugette in the Receiver play music list... [Re: nicolgw]
phaigh
Presumably, this is because the 'title' field is defaulted to the track name?
Paul.
2xEmpeg.
1xRioReceiver.
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#220344 - 15/10/2001 02:39 Re: Bugette in the Receiver play music list... [Re: phaigh]
This behaviour is by design. Hopefully, a future update will list "(None)" as a valid option in the menu.
