So, what is the specific location I should upload this patch to?If I understand things correctly, you don't upload a patch. You should only upload full kernels.
If what you have is genuinely a "patch", then it's not something you want to upload. It's probably a piece of source code intended to be patched into the original kernel source code.
If that's the case, then you need to perform the source code patching and compile a new kernel yourself with the ARM-linux cross compiler. Once you have a new compiled kernel image, then you upload
that to the empeg.
Then again, I don't know what files you've got. If you've got a "kernel patch", that's one thing, and if you've got a "patched kernel", that's another thing.
Find out what you've got and get back to us...
And by the way, kernels go into location 10000 in the Empeg's flash.
