#221958 - 10/08/2002 08:40 Shoutcast Stream
loren
Alright... this is driving me nuts. I REALLY want to have some shoutcast streams through my reciever, but i'm having no luck. Both RRR and Rioplay work fine for serving up local music, but when i try and get a shoutcast stream i get nothing.
I'm behind a BBIAgent linux router, and my reciever is a Dell branded one. Would either of these factors matter in getting shoutcast to stream?? I need my shoutcast!
Thanks!
-loren
|| loren ||
#221959 - 11/08/2002 13:38 Re: Shoutcast Stream [Re: loren]
fvgestel
Loc: Netherlands
Loren,
You need to make sure your firewall/router is accepting the receiver's IP-address for NAT/IP-masquerading. Also check the "default gateway"-option of the DHCP-reply. It should be the IP-address of the linux box
Frank van Gestel
#221960 - 12/08/2002 04:17 Re: Shoutcast Stream [Re: loren]
mardibloke
Loc: Penarth, UK
Running fine with my couple of DAR's. So guess its a router / firewall issue. Can you get shoutcast streams working to a PC on your home network ?
Rod, UK
#221961 - 12/08/2002 12:27 Re: Shoutcast Stream [Re: loren]
dave
Loc: San Diego, CA
I don't know anything about this firewall, but if you set a PC to the same IP address that the Rio uses, can you ping the Shoutcast server?
#221962 - 24/09/2002 17:04 Re: Shoutcast Stream [Re: dave]
loren
*sigh* i tried all of your suggestions. No go STILL. I've upgraded to RRR 7.10, Reciever Manager 1.03, and the same results. I can get shoutcast going on any other computer, just not the reciever. It just freezes. It wouldn't make sense for it to be a router issue if it works on every other computer, without any special rules for shoutcast on the router. Any other ideas??
|| loren ||
#221963 - 24/09/2002 21:30 Re: Shoutcast Stream [Re: loren]
dionysus
Loc: San Francisco, CA
make sure that the rio reciever's ip address can see the rest of your local network..
I had a problem when iptables was blocking my local network from my linux box - for some reason riplay/rrr both wanted to talk directly to the dhcp (or maybe jrecevier?) server...
iptables -t filter -A INPUT -d $LOCALNET -s $LOCALNET -j ACCEPT
fixed the problem for me..
-m
#221964 - 24/09/2002 21:33 Re: Shoutcast Stream [Re: dionysus]
loren
but did that preclude your reciever from working at all or just from receiving shoutcast streams? As far as i can tell it can see the whole network.
|| loren ||
#221965 - 24/09/2002 23:32 Re: Shoutcast Stream [Re: loren]
dionysus
w/ older versions of rioplay, (.28), everything worked except for shoutcast..
w/ rrr and newer versions of rioplay, it would crash upon startup..
-m
#221966 - 25/09/2002 05:56 Re: Shoutcast Stream [Re: dionysus]
happy_hammer66
newbie
I suggest you setup an internal shoutcast server and get your clients working with this first. Then you can work on external shoutcast sites. It's not a big deal to get going,i use it to stream my local FM radio station to mu receivers.
bill
#221967 - 25/09/2002 11:14 Re: Shoutcast Stream [Re: happy_hammer66]
loren
good idea.. didn't think of that. I'll try that out tonight.
|| loren ||
#221968 - 25/09/2002 22:55 Re: Shoutcast Stream [Re: loren]
dionysus
Check out streamsicle - http://streamsicle.com/ a very easy to configure/use mp3 streamer (uses your current mp3's..) for Windows..
I'm actually using this in-play of playlists/etc on the rioreceiver - it's a jukebox-style web page which can stream to the rio receiver, with a very clean interface.
Check it out.
-m
