I've been avoiding dealing with a few bugs, but I finally decided to deal with them. This version is only located at
http://www.reza.net/rio/receiver-0.7.8.arf
and not on sourceforge yet (though it's checked into CVS). It's been minimally tested, but it seems to work. The flac support should work with jRec (untested), or you can specify a url to the flac file directly if it's sitting on some web-server. Just replace the 'http' with 'flac' (for example, flac://server/path/some_file.flac).
I've done some code cleanup, added a 'Play All' feature, added code to save configuration changes to the filesystem in case you're not running the windows server software, and some other back-end changes to make it more jRec friendly.
Let me know how this works out.
Reza
