#222962 - 28/03/2003 12:59 Implementing Favorites
pauljlucas
Loc: California
So I wrote server code to handle favorites and tested it with a test client and it works fine. However, trying it with the real Rio, nothing happens. I make a selection, press List, enter a number, press Enter -- nothing happens.
I'm using tcpdump to dump all UDP packets originating at the Rio:
sudo tcpdump -i eth0 -nn -t -X src host 10.0.1.10 and udp
I do see stuff go by for the initial SSDP requests, however. Any ideas as to why the Rio apparantly isn't sending anything to the server?
- Paul
#222963 - 28/03/2003 13:06 Re: Implementing Favorites [Re: pauljlucas]
Once it gets past ssdp, isn't all the communication TCP?
#222964 - 28/03/2003 13:09 Re: Implementing Favorites [Re: wfaulk]
pauljlucas
Loc: California
Not according to http://www.dasnet.org/david/rio/protocol.html
Anyway, I also tried using tcpdump for ALL packets, both TCP and UDP: still nothing when I hit Enter.
- Paul
#222965 - 28/03/2003 14:32 Re: Implementing Favorites [Re: pauljlucas]
Oops. Right. NFS. Forgot about that.
#222966 - 29/03/2003 12:34 Re: Implementing Favorites [Re: pauljlucas]
FWIW I never figured that stuff out either. The Receiver server in the Rio Central plain doesn't support it, and nobody has ever noticed. Roger? any offers?
#222967 - 31/03/2003 05:44 Re: Implementing Favorites [Re: peter]
The favourites stuff is supposed to work using the "State?" / "State!" UDP stuff. Are you seeing any of this traffic (UDP, port 18678, IIRC)?
#222968 - 31/03/2003 09:52 Re: Implementing Favorites [Re: Roger]
pauljlucas
Loc: California
I also wrote code to implement the State? stuff on port 18678. The Rio never responds (though it works fine otherwise). I also did a tcpdump and left it running for several hours. I never once saw the Rio spontaneously send its state information out.
- Paul
#222969 - 01/04/2003 00:09 Re: Implementing Favorites [Re: Roger]
pauljlucas
Loc: California
OK, I had a friend with both a Windows and Linux box do some testing for me. He had tcpdump running on the Linux box and was using the stock Windows Rio server. He attempted to store a favorite: it didn't work. It seems like this feature is totally broken (which is kind of hard to believe). He didn't see any UDP traffic via tcpdump either (which is consistent with the feature not working and also consistent with the behavior of my Rio).
Any ideas?? Does the Rio, during initial boot-up, do some kind of probe or handshake looking for a server on port 18678 and, if it doesn't find it, never send anything there again?
- Paul
#222970 - 01/04/2003 01:01 Re: Implementing Favorites [Re: pauljlucas]
I just used Ethereal to trace the conversation between my Windows server and the Rio Receiver sat on my desk.
The first UDP packet is sent from the server to the Receiver (i.e. not broadcast), containing "State?"
The response is sent from the Receiver to the server, containing "State!", and the FID and timecode. It also contains the Receiver's MAC address (due to a limitation in the Windows networking stack).
#222971 - 01/04/2003 01:32 Re: Implementing Favorites [Re: Roger]
pauljlucas
Loc: California
Does the favorites feature work for you? Also, out of curiosity, since the Rio is never totally off, does it reply to "State?" when in low-power mode?
- Paul
#222972 - 01/04/2003 01:55 Re: Implementing Favorites [Re: pauljlucas]
Dunno. I can't find my remote.
Yes, I think so.
