#223214 - 31/05/2003 18:25 tRio killing my network
dionysus
Loc: San Francisco, CA
Got tRio working w/ Jreceiver 0.2.5, problem is, it completely kills my internet connection..
My setup has my dsl ethernet plugging into an 8 port switch; w/ the receiver/wireless gear/internal servers/etc on the same switch.. When tRio is running, my ping times go from their usual 20-40ms up to 15000-16000ms (obviously not acceptable:) )
Anyone else seeing this? why is tRio chattering so much?
-mark
#223215 - 31/05/2003 19:53 Re: tRio killing my network [Re: dionysus]
shawn
Loc: Silicon Valley
See this thread. Basically change trio.xml from multicast to unicast. I believe you lose synchronized players though.
#223216 - 03/06/2003 08:36 Re: tRio killing my network [Re: dionysus]
pauln
Mark,
Sorry for taking so long to respond - I've been off on holiday again. But it's back to the grindstone again now - sigh!
Did Shawn's suggestion help at all? I'm assuming that you're only experiencing these terrible ping timings when you're busy playing back music - is this right?
The other thing you could try is to change the send-method setting to "broadcast" and ensure that the broadcast-address is correct for your network. This should allow you to synchronise playback, provided that the players are on the same sub-network.
Please let me know how it goes.
Paul
Paul (the tRio guy)
#223217 - 12/06/2003 16:53 Re: tRio killing my network [Re: pauln]
dionysus
Hey guys,
The unresponsiveness was indeed only when music was being played back.. I actually run a server on my dsl connection ( http://mvgals.net ) and it resulted in the server essentially being kicked off the web:( (and it took me ~2-3 hours w/ sbc tech support/etc to finally narrow it down to the newly working but forgotten about trio:) )
I'm wondering, is this because the default broadcast address for trio tries to go over the i-net?
I'll try making the changes when I have time.. (I'm actually out of town and have been for past few weeks.)
-mark
#223218 - 25/06/2003 20:30 Re: tRio killing my network [Re: dionysus]
adamcb
I am experiencing a very similar problem. It plays for few minutes as long as I don't mess with the menus before it freezes. If I mess with the menus it freezes much sooner. I'm running 1.3 alpha 2 on the Mercury 1.3 server.
Thanks,
Adam
