#223427 - 04/08/2003 09:51 tRio, JReceiver and Playlists
jdc0730
Loc: Indianapolis, IN
Currently using tRio 0.1.3alpha2 and JReceiver 0.2.5 with no problems save one. I am unable to play any playlist files through tRio. They appear fine in the web interface of JReceiver, but when I pull them up on tRio, none of the songs listed are correct. Is this a known issue or am I missing something? I have tried MSU and PLS playlists with the same results.
Thanks for the help.
Jeff
#223428 - 04/08/2003 13:32 Re: tRio, JReceiver and Playlists [Re: jdc0730]
mmhere123456
newbie
I've seen the same thing, and posted it in the "tRio 0.1.3 testing" thread over in the General section.
I've also noticed that, while the lists are incorrect on the Rio client display, if you select one of the incorrectly labelled items to play the correct song begins playing. I see this behavior [incorrect song title displayed but correct song plays] in Jukebox mode. In the "tRio 0.1.3 testing" thread I said:
Sometimes the track names displayed on the client are incorrect, yet the "correct" track plays if you select the mislabelled item from the screen. Example: when selecting a starting point in Jukebox mode, I scrolled to Steve Miller Band -> Abracadabra, and expanded the Abracadabra album title to reveal its tracks. Instead, I saw what looked like a list of all tracks on the server (across all artists/albums) listed in alpabetical order, and starting somewhere in the 'S's. These tracks did not belong to the album Abracadabra. Yet when I selected the first listed track, the client began playing the first track from Abracadabra. So the right thing began to play, but the selection list was messed up. The playback display did show the correct track info.
PaulN ???
Edited by mmhere123456 (04/08/2003 13:35)
#223429 - 04/08/2003 13:55 Re: tRio, JReceiver and Playlists [Re: mmhere123456]
pauln
Yup, we do seem to have a problem, Houston. I'm starting work through some of the outstanding bugs in preparation for 0.1.4 and I'll this is on my list.
Paul
p.s. do you ever check your Personal Messages? i pm'd you the other day, but you don't seem to have read it.
Paul (the tRio guy)
#223430 - 05/08/2003 02:04 Re: tRio, JReceiver and Playlists [Re: pauln]
mmhere123456
newbie
Do I check my PMs
D'Oh! I have my login for this site configured to take me to the main msg indices. As such, I don't seem to check my personal page very often.
I see your recent responses, and have replied.
Thanks again for your work on tRio.
#223431 - 05/08/2003 15:26 Re: tRio, JReceiver and Playlists [Re: jdc0730]
pauln
Jeff
I've tracked this problem down now. The fix will be included 0.1.4.
Paul
Paul (the tRio guy)
