#223435 - 14/08/2003 07:30 Ogg problem in trio and rioplay
donp
I have found that if I play a monophonic ogg vorbis file in trio or rioplay (same decoder?) it appears to play at 2x speed and 2x pitch.
#223436 - 14/08/2003 11:22 Re: Ogg problem in trio and rioplay [Re: donp]
pauln
Hey, that could sound quite amusing - for at least the 1st 15 seconds.
A sample encoding would help to sort this out for tRio. I'll PM you with my email address.
Paul
Paul (the tRio guy)
#223437 - 19/08/2003 05:56 Re: Ogg problem in trio and rioplay [Re: pauln]
donp
I installed the new 0.1.4.alpha4 and mono ogg files work fine. Thank you!
#223438 - 25/08/2003 06:16 Re: Ogg problem in trio and rioplay [Re: donp]
donp
I ran across another problem Ogg file, still with high pitch. This one is
mono encoded at 22 khz sample rate, roughly 20 kb/s. I can send the file.
