#223589 - 02/09/2003 19:34 tRio 0.1.4 alpha 4 - Clock problems
bha
Paul - again, really really great work. I have tRio 0.1.4alpha4, Jrec 0.2.5, linux, Java 1.4.2 & J2RE, IE6.
I just noticed over the weekend that the clock does not seem to work.
The time is correct when it goes into Standy. But it doesn't change. If I reboot the unit then Standby it will have the correct time, but then doesn't update.
This was working for me under 0.1.3alpha 2. Maybe my trio.xlm is screwed up, I'll look into this some more.
Anybody else have this? Is this a bug worth reporting?
#223590 - 02/09/2003 20:48 Re: tRio 0.1.4 alpha 4 - Clock problems [Re: bha]
Jerz
Loc: Jesusland
All clocks appear to be working fine.
#223591 - 02/09/2003 22:22 Re: tRio 0.1.4 alpha 4 - Clock problems [Re: Jerz]
bha
Thanks. Sometimes one just needs to hear that it is working for somebody else to inspire them to work harder.
I have shut it all down, fixed a few little issues in my XML, and started everything back up, and the clocks do seem to be working correctly (as they did before my upgrade).
Thanks again.
#223592 - 03/09/2003 03:35 Re: tRio 0.1.4 alpha 4 - Clock problems [Re: bha]
Jerz
Loc: Jesusland
I know exactly what you mean.
