#223844 - 08/10/2003 07:55 tRio Web Interface without a Web Browser
basf_audio
newbie
Loc: Saint Louis
I was curious to know how to run the tRio Web interface just from a java command line. I have a really slow tablet that isn't really cutting it. So I thought I'd try a way to run the java part outside of MS Explorer. (It does run in the Web browser - but IE takes up enough memory already...)
Thanks!
_dave
#223845 - 09/10/2003 01:34 Re: tRio Web Interface without a Web Browser [Re: basf_audio]
pauln
Dave,
You'd have to run it via an applet viewer (see http://java.sun.com/j2se/1.4.2/docs/tooldocs/windows/appletviewer.html ). This comes as part of the java SDK and isn't included in the JRE install.
I think the command you'd use is something like:
appletviewer http://xxxxx:8090/trio-applet.htm
Paul
Paul (the tRio guy)
#223846 - 09/10/2003 22:15 Re: tRio Web Interface without a Web Browser [Re: pauln]
basf_audio
newbie
Loc: Saint Louis
Paul,
That did the trick... I was trying to grab the page and start the appletviewer.exe locally... But with a lot of errors... Hitting it via HTTP worked well... Now on to some testing...
Thanks!
Dave
