#223850 - 08/10/2003 20:16 Trio with ARM and XP web problem
msk
Trio is great...but, I can't get the web interface to work right. I see the player correctly listed on the left pane and the status is properly updated, but when I click on the Player tab, nothing happens. My Java console shows an error of java.lang.illegalArgumentException: SetSelectedIndex: 2 out of bounds.
Everything else seems fine...Shoutcast works, mp3's work, predefined (musicmatch) playlists work...Java version is 1.4.2.01
Any ideas!???
Please help! THANKS IN ADVANCE!
#223851 - 09/10/2003 01:40 Re: Trio with ARM and XP web problem [Re: msk]
pauln
Hmmm, I thought I'd fixed a problem like this some time back. There should be a "stack trace" after the error message in the java console. I need to know what this says.
Paul
Paul (the tRio guy)
#223852 - 09/10/2003 04:21 Re: Trio with ARM and XP web problem [Re: msk]
happy_hammer66
newbie
this happens quite often. Seems to be more likely to happen when one of the players is in listen mode and the host rio is on a station and you change setting on the host rio.
#223853 - 19/10/2003 17:47 Re: Trio with ARM and XP web problem [Re: pauln]
cobrien411
Just installer tRio - love it...
I'm getting this issue too. Stack trace follows...
Thanks!
Chris
TRioApplet.init(): null
Parameters. trio-server: 192.168.1.4, rmi-port: 1099
Exporting Remote
Finding remote server
Loaded Application. Name: player, title: Player
Loaded Application. Name: clock, title: Clock
Listed applications: 2
Listed units: 2
Loaded Unit. Name: Upstairs, ip: /192.168.1.9
Loaded Unit. Name: Kitchen, ip: /192.168.1.3
java.lang.IllegalArgumentException: setSelectedIndex: 2 out of bounds
at javax.swing.JComboBox.setSelectedIndex(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.getModePanel(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.init(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.<init>(Unknown Source)
at trio.applet.TRioApplet.getUnitApplicationPanel(Unknown Source)
at trio.applet.TRioApplet$2.stateChanged(Unknown Source)
at javax.swing.JTabbedPane.fireStateChanged(Unknown Source)
at javax.swing.JTabbedPane$ModelListener.stateChanged(Unknown Source)
at javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
at javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
at javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
at javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
at javax.swing.plaf.basic.BasicTabbedPaneUI$MouseHandler.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
#223854 - 01/11/2003 13:08 Re: Trio with ARM and XP web problem [Re: cobrien411]
pauln
I think I've tracked this one down. Please PM me with you email address and I'll send you something to test.
Paul (the tRio guy)
#223855 - 16/11/2003 09:30 Re: Trio with ARM and XP web problem [Re: pauln]
cookie
Does the fix for this work, I have same issue. Thanks for great product so far!
#223856 - 16/11/2003 13:07 Re: Trio with ARM and XP web problem [Re: cookie]
pauln
Yes, PM me your email address and I'll send you the files.
Paul
Paul (the tRio guy)
#223857 - 24/02/2004 22:01 Re: Trio with ARM and XP web problem [Re: pauln]
leeep
i too am having this problem. PM sent.
i assume this is a reparable problem. thanks!
-e
#223858 - 26/02/2004 04:41 Re: Trio with ARM and XP web problem [Re: leeep]
Fiatz79
Loc: Sterling, VA - USA
Think I may have hit the same wall. Strange though. Just showed up after hitting about 7900 tracks. Using arm 1.4 on a Win2K server. Also found a strangeness choosing a few albums. Track list won't always open for a few recently added albums on the Rio but will on the Web interface. Takes a long time though and just with those 1 or 2 albums. Rebuilt the database twice.
Ron Sitnick
