Okay, I'm back to the same point I was yesterday with the screen coming up.
Here's what happens when i run it-
1st - I start ARM. The ARM icon on the computer is red at this point.
2nd - I turn on the Receiver. The Trio screen pops up and it reads "Finding Trio Server". This message will not change until I open up trio.bat.
3rd - I open trio.bat. When this happens the DOS windows opens and scrolls. It stops after reading connection accepted by receiver. Once the scrolling stops, I then check the receiver. A screen pops up that has a square at the bottom left and says "queue" under it. Next to the square it says Received 1 in very small print. To the right and a bit underneath it reads --:-- . When I hit the menu button on the remote, a menu pops up with options including Artist, Song, Playlist, Settings, Clock, etc... When I choose any of the music options (song, playlist, etc) it reads in large letters at the top of the screen "Server Error" then below is smaller letters "Unable to connect to Audio Receiver Manager server. Please ensure this is running and correctly configured. Cause: connection refused. Connect" No music is listed.
After that, I check the DOS box on the computer which reads what I printed below. The entire time, the ARM icon on the computer remains red, instead of blue.
Below I've copied the info that remains in the DOS box. When you asked earlier what happens in the Trio log and Java console, I'm not sure what those are, but I'm assuming I gave you enough info. Let me know if there's anything else you might need. Once again, thanks for all the help!
Text in DOS box from trio.bat -
C:\Program Files\trio-0.1.4.alpha5\bin>set TRIO_HOME=c:\Program Files\trio-0.1.4
.alpha5
C:\Program Files\trio-0.1.4.alpha5\bin>set JAVA_HOME=c:\Program Files\java\j2re1
.4.2_01
C:\Program Files\trio-0.1.4.alpha5\bin>cd c:\Program Files\trio-0.1.4.alpha5
C:\Program Files\trio-0.1.4.alpha5>java -X"bootclasspath:c:\Program Files\trio-0
.1.4.alpha5\lib\pja-mod.jar;c:\Program Files\java\j2re1.4.2_01\lib\rt.jar" -Dawt
.toolkit=com.eteks.awt.PJAToolkit -Djava.class.path="c:\Program Files\java\j2re
1.4.2_01\lib\tools.jar;c:\Program Files\java\j2re1.4.2_01\lib\jsse.jar;c:\Progra
m Files\trio-0.1.4.alpha5\lib\trio-0.1.4.jar;c:\Program Files\trio-0.1.4.alpha5\
lib\commons-logging.jar;c:\Program Files\trio-0.1.4.alpha5\lib\commons-beanutils
.jar;c:\Program Files\trio-0.1.4.alpha5\lib\commons-collections.jar;c:\Program F
iles\trio-0.1.4.alpha5\lib\commons-digester.jar;c:\Program Files\trio-0.1.4.alph
a5\lib\commons-lang.jar;c:\Program Files\trio-0.1.4.alpha5\lib\jrcommon.jar;c:\P
rogram Files\trio-0.1.4.alpha5\lib\jrutil.jar;c:\Program Files\trio-0.1.4.alpha5
\lib\jrclient.jar;c:\Program Files\trio-0.1.4.alpha5\lib\xmlrpc.jar" trio.TRioSe
rver "-cc:\Program Files\trio-0.1.4.alpha5\trio.xml"
Start of TRioServer. Version 0.1.4.alpha5
Defaulted http document root to: C:\Program Files\trio-0.1.4.alpha5
Loading TRioPlayerLayout: universal
Loading TRioPlayerLayout: windows
ImageTranslation: byte-binary
RMI Registry created sucessfully on port 1099
binding rmi: <a href="rmi://172.16.xxxx:1099/TRioServerRemote" target="_blank">rmi://172.16.xxxx:1099/TRioServerRemote</a>
binding rmi: <a href="rmi://OFFICE.gateway.2wire.net:1099/TRioServerRemote" target="_blank">rmi://OFFICE.gateway.2wire.net:1099/TRioServerRemote</a>
Creating sockets
creating udp socket. local port: 19680, timeout: 15000
Http server opening port 8090
Http server listening on port 8090
Got connect from /172.16.xxxx
TRioUnitControlThread (/172.16.xxxx): Starting
TRioUnitControlThread (/172.16.xxxx): Waiting for Rio to accept connection. ip:
/172.16.xxxx, port: 19682
TRioUnitControlThread (/172.16.xxxx): Rio has accepted connection. Interface: /
172.16.xxxx
*** start of TRioPlayerSelectionDlg. listType: class trio.player.TRioPlayerArti
st, parentSelection: null
sending Query query:
http://67.65.154.xxx:12078/query?artist=
Error: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Sour
ce)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown So
urce)
at java.net.URLConnection.getContent(Unknown Source)
at trio.player.TRioPlayerARMServer.doQuery(Unknown Source)
at trio.player.TRioPlayerARMServer.listArtists(Unknown Source)
at trio.player.TRioPlayerSelectionDlg.populateListModel(Unknown Source)
at trio.player.TRioPlayerSelectionDlg.init(Unknown Source)
at trio.player.TRioPlayerSelectionDlg.<init>(Unknown Source)
at trio.player.TRioPlayerQueueMode.actionSelectMusic(Unknown Source)
at trio.player.TRioPlayerQueueMode$1.actionPerformed(Unknown Source)
at trio.gui.TRioMenuDialog.itemSelected(Unknown Source)
at trio.gui.TRioMenuDialog$2.keyPressed(Unknown Source)
at java.awt.AWTEventMulticaster.keyPressed(Unknown Source)
at java.awt.Component.processKeyEvent(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at trio.gui.TRioKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at trio.gui.TRioWindowManager.dispatchKey(Unknown Source)
at trio.gui.TRioKeyDispatcher.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
ce)
urce)
ce)
urce)
No key mapping found for IR Code - discarding. IR Code: 411
