I have successfully been running trio + arm for a few months, but when I use "Listen", I get constant and unacceptable drop-outs with the listening receiver(s). I have 4 DDARs. From reading what others have said, I thought Jrec might solve the problem.
So, I have successfully installed Jrec (can see my files and can play them via Winamp. I have left ARM running for the DHCP for trio and do get the receivers to recognize the server. I also finally got trio to see the content again. So, I think Jrec and trio are working together, but I can't do anything within Jrec to get the Receivers to play. For example, if I click to play within jrec on a playlist, it kicks on Winamp, but nothing happens with the Receivers. How do I do this?
Also, after all this work, I am still getting the unacceptable drop-outs (seems like every 10 seconds or so). Any thoughts? I have tried different switches (currently using Netsys 16-port switch and a router.
Thanks for the help!
Rich
