#224450 - 19/01/2004 00:19 Stock 1.04 + YAARS 1.1: Repeat/Random Problem
Lion
Loc: Minnesota
I've got my Rebranded DELL/SonicBLUE Receiver using the stock 1.04 software combined with YAARS 1.1 .. I went with YAARS becuase of the simple setup, but I've got a problem with the Receiver that I don't know how to fix. When I have REPEAT set, it doesn't actually repeat! It reaches the end of it's list and stops playing. I have to reload the playlist. If RANDOM is turned on, the Receiver will play from one spot ont he list to the end of the list, and then stop. Depending on where it picks the "spot", it could be just a few songs fromt he end of the list!
Any suggestions on how to fix this?
Thanks!
Rio Receiver + Linux (RH9)
#224451 - 21/01/2004 17:56 Re: Stock 1.04 + YAARS 1.1: Repeat/Random Problem [Re: Lion]
Lion
Loc: Minnesota
Ok, I've tracked this problem a little bit more. It seems when it gets to the LAST SONG in the un RADMON'd playlist, it stops. If I turn off RANDOM, then push FFW and play again, it will continue!
#224452 - 08/03/2004 10:47 Re: Stock 1.04 + YAARS 1.1: Repeat/Random Problem [Re: Lion]
ukengb
Loc: United Kingdom
As you are using YARRS, could I ask if you have the same problem I do? How big is your Master Playlist File (htdocs/content/100)? I have found that if it's larger than 18872 bytes the Receiver gives an error.
I'm hoping to find someone slse who can test this to confirm it's not my setup. I don't think it's YARRS either, but YARRS is the easiest way to reproduce the problem.
