#224558 - 06/02/2004 21:56 Help request - Cocktail party, no music, and :(
shawnharper
Hi everybody. I'm trying to get tRio working again after a few month lapse where I went back to straight ARM (We're having a cocktail party at our new home, and my wife wants music playing - gotta get this working or I'm in trouble).
Thanks!
I've got tRio installed OK, but when I open the front end, and click on "album" from que n' play, I get the following error:
sending Query query: http://192.168.1.2:12078/query?source=
Updating config file
Error: java.net.ConnectException: Connection timed out: connect
Here's the entier command prompt info if that helps...
C:\Program Files\tRio-0.1.4\bin>set TRIO_HOME=c:\Program Files\trio-0.1.4
C:\Program Files\tRio-0.1.4\bin>set JAVA_HOME=c:\Program Files\\java\j2re1.4.2_01
C:\Program Files\tRio-0.1.4\bin>cd c:\Program Files\trio-0.1.4
C:\Program Files\tRio-0.1.4>java -X"bootclasspath:c:\Program Files\trio-0.1.4\lib\pja-mod.jar;c:\Program Files\\java\j2r
e1.4.2_01\lib\rt.jar" -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.class.path="c:\Program Files\\java\j2re1.4.2_01\lib
\tools.jar;c:\Program Files\trio-0.1.4\lib\trio-0.1.4.jar;c:\Program Files\trio-0.1.4\lib\commons-logging.jar;c:\Program
Files\trio-0.1.4\lib\commons-beanutils.jar;c:\Program Files\trio-0.1.4\lib\commons-collections.jar;c:\Program Files\tri
o-0.1.4\lib\commons-digester.jar;c:\Program Files\trio-0.1.4\lib\commons-lang.jar;c:\Program Files\trio-0.1.4\lib\jrcomm
on.jar;c:\Program Files\trio-0.1.4\lib\jrutil.jar;c:\Program Files\trio-0.1.4\lib\jrclient.jar;c:\Program Files\trio-0.1
.4\lib\xmlrpc.jar" trio.TRioServer "-cc:\Program Files\trio-0.1.4\trio.xml"
Start of TRioServer. Version 0.1.4.alpha4
Defaulted http document root to: C:\Program Files\tRio-0.1.4
Loading TRioPlayerLayout: universal
Loading TRioPlayerLayout: windows
ImageTranslation: byte-binary
RMI Registry created sucessfully on port 1099
binding rmi: rmi://192.168.0.108:1099/TRioServerRemote
binding rmi: rmi://SHAWNSC17:1099/TRioServerRemote
Creating sockets
creating udp socket. local port: 19680, timeout: 15000
Http server opening port 8090
Http server listening on port 8090
Got connect from /192.168.0.105
TRioUnitControlThread (/192.168.0.105): Starting
TRioUnitControlThread (/192.168.0.105): Waiting for Rio to accept connection. ip: /192.168.0.105, port: 19682
TRioUnitControlThread (/192.168.0.105): Rio has accepted connection. Interface: /192.168.0.108
&&&& TRioUnit disconnected
ClockApp - hiding frame
PlayerApp - stopping stream
PlayerStream (/192.168.0.105) - stopStream()
PlayerStream () - stopStream()
PlayerApp - hiding frame
TRioUnitControlThread (/192.168.0.105): Ending
Got http request: GET /trio-applet.htm HTTP/1.1
Got http request: GET /trio-applet-0.1.4.jar HTTP/1.1
Got http request: GET /images/rio-small.gif HTTP/1.1
getting image: file:/C:/Program Files/tRio-0.1.4/images/rio-small.gif
Got http request: GET /trio/player/TRioPlayerARMServer_Stub.class HTTP/1.1
**** getting class: jar:file:/C:/Program%20Files/tRio-0.1.4/lib/trio-0.1.4.jar!/trio/player/TRioPlayerARMServer_Stub.cla
ss
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.URLConnection.getContent(Unknown Source)
at trio.player.TRioPlayerARMServer.doQuery(Unknown Source)
at trio.player.TRioPlayerARMServer.listAlbums(Unknown Source)
at trio.player.TRioPlayerARMServer.listAlbumsSH(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
at sun.rmi.transport.Transport$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
#224559 - 07/02/2004 06:24 Re: Help request - Cocktail party, no music, and :( [Re: shawnharper]
pauln
It looks like you've forgotten to edit trio.xml and change the url setting for ARM.
Paul
Paul (the tRio guy)
