I just received my extra MK II sled and I dutifully mounted it under my desk at work and hooked it up to a 12V computer power supply I saved from the garbage heap.
I have a question on the hookup.
I hooked the memory and the ign sense wires together. This seemed to cause a problem as I could never get my Empeg to shut down properly. I would push and hold the top button until it went on standby, but when the player started back up it didn't remember where it had left off. I decided that I probably needed to disconnect the ign sense wire and put a switch in, but I then noticed that the fuse on the memory wire had blown.
I don't know if that was caused by hooking the ign sense and memory wires up together or by some unseen short while I was hooking all of this up.
Any suggestions?
thanks
John
___
John Turner
"It's easier to ask for forgiveness than to ask for permission"
