I can't see an easy way to do it. I'm not sure if it is possible to do a soup on two variables, ie "artist=x, track=y", but you'd still have to know which tracks were candidates.
This is something that would really need to be put into JEmplode. Algoritmically it's fairly easy - select all tracks, sort by title, step through list comparing each title to the previous title. If a match is found, compare artist. If matching, verify FIDs are different (or maybe even check the track data?), create playlist with both tracks. Whilst following track also matches criteria append to playlist, Continue step-compare otherwise until done.
But I can't see why Mike would be motivated to do this. Do people often need to create playlists of this nature?
