#227209 - 15/07/2004 10:59 USB: Non-standard request
pim
Anyone seen this before? This is on my spare player, which I
didn't use for a long time. I was hoping to use it for the new
<censored>.
I suppose the USB hardware is broken. I don't use USB on it at all, but it
prevents my player to continue booting. Maybe I could compile my
own hijack kernel and leave USB support out. Or would there be an
easier way?
Anyway this is the log:
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v397 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Wed Jul 14 18:18:34 EDT 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000447) 12MB DRAM
Command line: mem=12m
Memory: 10960k/12M available (980k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=e7)
empeg usb initialised, PDIUSBD12 id ffff
This repeats endlessly... I've tried several kernels, without difference.
Pim
#227210 - 15/07/2004 11:02 Re: USB: Non-standard request [Re: pim]
One of the data lines is borked. Thats why it can't find the CS4231A chip or PDIUSBD12 chip.
Usually the cause is one of the chips dying mysteriously
#227211 - 15/07/2004 11:10 Re: USB: Non-standard request [Re: tman]
pim
Right. Didn't even notice the CS4231A failure. I could live without
the USB, but probably not without the CS4231A, even for using
it as <censored> ...
Pim
#227212 - 15/07/2004 14:26 Re: USB: Non-standard request [Re: pim]
even for using it as <censored> ...
The rio receiver thing is out of the bag...you can say it.
#227213 - 15/07/2004 17:58 Re: USB: Non-standard request [Re: JBjorgen]
It ain't the rio reciever software, why would he want aux in for that?
#227214 - 16/07/2004 13:10 Re: USB: Non-standard request [Re: andym]
pim
I thought the CS4231A was the main sound chip.
You're saying it's only used for AUX?
And yes, I was going to use it with v3a8 RE.
But having to buy a wireless ethernet bridge, as
well as having to fix this player, I now consider
buying a wireless squeezebox instead.
Thanks,
Pim
#227215 - 16/07/2004 13:12 Re: USB: Non-standard request [Re: andym]
I'm feeling so incredibly right! *sticks out tounge*
I know Stu's swapped out that chip before. It can probably be fixed.
More info here
Edited by JBjorgen (16/07/2004 13:17)
#227216 - 16/07/2004 13:31 Re: USB: Non-standard request [Re: pim]
Keep in mind that you don't actually know what the real problem here is.
This is the main peripheral data bus for the player, so any of the following can be the cause of the fault: IDE, USB, ethernet, sound-chip, buffer.
I have traced this problem for two players so far. In one case, it was the IDE header; in another, it was the ethernet controller.
#227217 - 16/07/2004 14:49 Re: USB: Non-standard request [Re: mlord]
pim
Come to think of it; some months ago, I bought an mk2a on eBay to replace my mk2.
I switched harddrives, and never bothered to check whether the now redundant
mk2 would startup with the new empty disk.
So it may well be an IDE cabling problem.
Thanks,
Pim
#227218 - 25/07/2004 20:33 Re: USB: Non-standard request [Re: tman]
schofiel
The 4231A, which also pulls down the IDE power line for the disk drives occasionally. You need a new chip.
#227219 - 25/07/2004 20:36 Re: USB: Non-standard request [Re: JBjorgen]
schofiel
It can be done. I have the remaining empeg stock.
#227220 - 28/07/2004 00:27 Re: USB: Non-standard request [Re: schofiel]
CFinch106
Is there any reason that my USB will stop responding? For a while it transfers songs fine, then it hangs up on one of them and the rest are timed out. It's really hard to transfer songs if I have to do about 10 at a time from 8 gigs of music.
#227221 - 28/07/2004 10:08 Re: USB: Non-standard request [Re: CFinch106]
edsmiata
Loc: New Jersey
are you using XP..if so you need to update the driver...as i found out!!!!
#227222 - 28/07/2004 16:53 Re: USB: Non-standard request [Re: CFinch106]
Yes, as Edsmiata said, this is a common reason.
#227223 - 28/07/2004 18:10 Re: USB: Non-standard request [Re: tfabris]
CFinch106
I saw that, but I'm on Windows2k.
#227224 - 28/07/2004 18:41 Re: USB: Non-standard request [Re: CFinch106]
If the USB driver also works under Windows 2000 (not sure if it does, the 2.0 release notes will probably say so if it doesn't), then try updating to that version of the driver anyway. Make sure you're on version 2.0 final on the player and on Emplode. Make sure your PC is updated with the latest flash BIOS for its motherboard, and that Windows 2000 has installed the latest drivers for that motherboard's USB chipset. Finally, make sure your empeg isn't having any hard disk trouble.
