#228180 - 22/07/2004 23:15 Mac address?
Jemmi
Is there a way to find out the MAC address from the case of the Rio Receiver? I am trying this xPL thing and have the receiver connected to a router... the router has MAC address filtering enabled for security so I want to add the receiver mac address to the ok ones... but don't know what it is
Jemmi
#228181 - 23/07/2004 00:30 Re: Mac address? [Re: Jemmi]
Not from the case, but from the main menu. It's in the "About" menu.
#228182 - 23/07/2004 00:31 Re: Mac address? [Re: tfabris]
Darn this integrated board. Again, I'm thinking that you're talking about an empeg car.
I know there's a way to do it with the receiver, gimme a bit to fiddle with it and find out.
#228183 - 23/07/2004 00:37 Re: Mac address? [Re: tfabris]
Seems to be the same on the Receiver. It's in the "About Receiver" menu. I think the field labeled "ID" is the MAC address. It looks like a MAC address anyway.
Of course, if your receiver isn't connecting the server, you can't get the "About Receiver" menu at all. But I could swear it puts up its MAC address if it doesn't connect. Doesn't it? Anyone?
If it doesn't, then temporarily plugging into a hub instead of that mac-blocking router will get you far enough to see the About menu.
#228184 - 23/07/2004 13:24 Re: Mac address? [Re: tfabris]
jem7784
Tony, That is what I did... allowed all connections on router and voila had the Mac Address.
Thanks again, though. I thought for sure it was encoded into the serial number or something but it's not...
Jemmi
#228185 - 23/07/2004 16:09 Re: Mac address? [Re: jem7784]
It's vice-versa if I recall correctly. I think that one or more of the digits of the mac address is the same as the serial number. That's how they did it on the empeg car anyway.
