#228376 - 24/07/2004 15:25 sporadical reboots
brabax22
While playing - without any obviously reason. Serial log tell me this:
serial_notify_thread.cpp: 180:@@ #23110  0:00:32
ser
serial_notify_thread.cpp: 180:@@ #23110 0:00:33
seria
serial_notify_thread.cpp: 180:@@ #23110 0:00:34
player(30): memory violation at pc=0x0202c488, lr=0x0202f4ec (bad address=0x3333fy_thread.cpp: 180:@@ #a3f0 0:01:32
serial_notify_thre
338b, code 2)_notify_threa
pc : [<0202c488>] lr : [<0202f4ec>]
serial_
serial_notify_threa
sp : bddfeaa8 ip : bddffcc4 fp : bddffcd0
s
serial_notify_thread.cpp: 136
r10: 02151684 r9 : bddffd0c r8 : bddffd20
serial_notify_thread.cpp: 136:@@ V45ad.
r7 : bddffd1c r6 : 33333333 r5 : 02151ial_notify_thread.
Function entered at [<020ad438>] from [<020b4824>]
serial_notify_thread.cpp: 136:@@ V46118:@@ TD
r5 = 021515C0 r4 = BDDFFE40 serial_notify_thread.cpp: 1
Function entered at [<020b475c>] from [<020e9bbc>]erial_notify_thread.cpp: 136:@@ V48
r4 = 00000000serial_n
ser
Function entered at [<020e8330>] from [<020b45a0>]
seria
r8 = 0215D97C r7 = 0215D968 r6 = 020AD438 r5 = 00000007
se
serial_notify_thread.cpp: 136:@@ V500:00:01
r4 = 00000000
Function entered at [<020b44f0>] from [<020e9bbc>]@ #12e70 0:00:02
r5 = 00000000 r4 = 00000000ify_thread.cpp: 180:@@ #12e70
Function entered at [<bffffcbc>] from [<02188230>]a3f0 0:01:40rial_notify_thread.cpp: 180:@@ #12e70
Restored terminal settingsy_thread.cpp: 180:@@ #a3f0
Remounting first music partition re80:
Vcb: 0x407cd000
serial_notify_thread.cpp: 116:@@ N3
serial_notify_thread.cpp: 117:@@ F0x23110
serial_notify_thread.cpp: 118:@@ TJust Like Jesse James
serial_notify_thread.cpp: 119:@@ ACher
serial_notify_thread.cpp: 120:@@ GOther
Any Ideas ?
PS: MKIIa, Hijack 402, V2
#228377 - 24/07/2004 15:38 Re: sporadical reboots [Re: brabax22]
mcomb
Loc: San Carlos, CA
Thats the player app crashing and restarting. I don't fully understand how to interpret the dump, but I've been told in the past that similar behavior and dumps was due to the player running out of memory. Is this with a v3 alpha? Do you have reservecache set in your config.ini? Are there other applications running?
-Mike
#228378 - 24/07/2004 17:34 Re: sporadical reboots [Re: brabax22]
Could also be hard disk trouble, or just bad tracks having been put on the player. You also didn't say which software version you were running, at the moment only 2.0 final is known to be completely stable.
Make sure you're running software version 2.0 final, Make sure you're not running any third-party applications, remove reservecache from your config.ini if it's there, do a RAM test, check to see if it's a bad track, then check for hard disk trouble.
#228379 - 24/07/2004 18:17 Re: sporadical reboots [Re: tfabris]
Also, wasn't there a problem with running in notify mode a while back? You might want to turn that off as well. If it has been working all along, though, I also suspect a bad track.
#228380 - 25/07/2004 13:28 Re: sporadical reboots [Re: tfabris]
SE_Sport_Driver
He mentions "V2" in his post, 2.00 final?
#228381 - 26/07/2004 10:02 Re: sporadical reboots [Re: SE_Sport_Driver]
brabax22
Yes - Version 2 final. I tried yesterday to solve the problem with reinstalling 2.00 final. Now its better - but the restarts are still there.
Memory-Test show no errors. Reservecache is now commented in config.ini.
#228382 - 26/07/2004 12:37 Re: sporadical reboots [Re: brabax22]
The only reason to use reservecache in the first place is if you're running third-party applications. Did you comment those out, too?
