#229432 - 03/08/2004 05:55 Unable to format new drive
MattVogt2
Hi there, I'm hoping someone can help me - I'm having difficulty installing a new drive into my mk 2 empeg.
It currently has an original 18Gb disk and an aftermarket 20Gb disk, and I'm trying to replace them both with a single 80Gb disk.
Unfortunately, the builder ram image seems to be unable to format the new drive - I have tried it on the first and second IDE connector, with each of the master/slave/CS settings (it only boots with CS), etc. The disk is a Fujitsu MHT2080AT.
Here is a log of the unit's output booting with the new drive, and the builder image (captured via hyperterminal):
empeg-car bootstrap v1.00 20000601 ([email protected])
If there is anyone present who wants to upgrade the flash, let them
speak now,
or forever hold their peace...it seems not. Let
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done, booting
the kerne
l.
Linux version 2.2.14-rmk5-np17-empeg49 ([email protected])
(gcc versi
on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001
empeg-car player (hardware revision 7, serial number 80000279)
Command line: mem=12m
Calibrating delay loop... 207.67 B
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k
init)s.cpp 18
IP Protocols: ICMP, UDP, TCPd=5
Dentry hash table entries: 2048 (order 2, 16k)hash 16384 bhash
16384)econds
IrDA (tm) Protocols for Linux-2.2 (Dag Br
Stressi
Linux-IrDA: IrCOMM protocol ( re
POSIX conformance testing by UNIFIXs.cpp 189 ( 14): Poll result=0
Linux NET4.0 for Linux 2.2
ircomm_tty: virtual tty driver for IrCOMM ( re
hdstress.cp
Starting kswapd v 1
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)serial driver version
4.27
empeg audi
hda: FUJI
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTsed.
Signature is ffffffff 'ÿÿÿÿ'
hda: FUJITSU MHT208
empeg display initialised.
empeg dsp audio initialisedalised 0089/88c1 (save to d
empeg dsp mixer initialised
empeg dsp initialisedflash driver
hdb: FUJITSU MHT2080AT, ATA DISK drive 320 bl
hdb: FU
empeg single channel IDE drive
Probing primary interface...warn
hdb: FUJITS
hda: FUJITSU MHT2080AT, ATA DISK driveed
hda: FUJITSU MHT2080AT, ATA DISK driverupt, status=0xff, count=1unted
root (
hda: FUJITSU MHT2080AT, 76319MB w/8192kB Cache, CHS=9729/255/63nmount
old root ...
empeg-flash driver initialized) at 0x4008000 IRQ:7 INTF:TP M
smc chip id/revision 0x33491
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])ounting first
music partition
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC
00:02:d7:10:01:1
7
Partition check:
VFS: Can't
hda: hda1 < hda5 hda6 > hda2 hda3 hda4ISK: ext2 filesystem found at
block 0
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...(ext2 filesystem) readonly.
to unmount old root ... okay
Freeing unused kernel memory: 4k initVFS: Can't find an ext2 filesystem
on dev i
de0(3,4).
mount: wrong fs type, bad option, bad superblock on /dev/hda4,
or too many mounted file systems
warning: can't open /etc/mtab: No such file or directory
umount: /drive0: not mounted
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining
whether /dev/
hda4 is mounted.
no room for private writable mapping
error: -12
/dev/hda4: Memory allocation failed while setting up superblock
hdstress.cpp 189 ( 14): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Thanks for any information,
#229433 - 03/08/2004 06:40 Re: Unable to format new drive [Re: MattVogt2]
You want to read this and this.
#229434 - 03/08/2004 06:52 Re: Unable to format new drive [Re: Roger]
MattVogt2
Ok, thanks.
Any idea why the builder image doesn't work directly? Is 80Gb too large for <something>?
#229435 - 03/08/2004 07:29 Re: Unable to format new drive [Re: MattVogt2]
Yep.
#229436 - 03/08/2004 07:46 Re: Unable to format new drive [Re: Roger]
MattVogt2
Fair enough:)
Another problem (sorry to be montonous): I have put the current developer image back onto the player, and I'm now trying to quit the player and drop to the shell, as per the FAQ entry - however, the player does not give any indication that it is accepting commands from hyperterminal. In fact, the player app may have exited - is there some way I can access the shell from this position?
The boot log now ends with:
Press 'q' to go into development mode. You Have Zero Seconds to Compl
Starting player
player.cpp : 385:empeg-car 2.00 2003/04/01
! tags.cpp : 61:Failed to open tags (0xc0041002)
Vcb: 0x4054d000
Thanks again.
#229437 - 03/08/2004 08:14 Re: Unable to format new drive [Re: MattVogt2]
Control-C ???
#229438 - 03/08/2004 08:26 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
Control-C ???
Nope. In fact, there's no indication that any comms is getting from hyperterminal to the empeg. I've tried it with VT100 and TTY modes, the FAQ doesn't mention which of these (or any other) is appropriate...
#229439 - 03/08/2004 08:33 Re: Unable to format new drive [Re: MattVogt2]
Had you succeeded in building the drive at this point?
#229440 - 03/08/2004 08:37 Re: Unable to format new drive [Re: MattVogt2]
That's usually an indication that you've got flow control turned on. Confirm your settings are set to 115200 8N1, no flow control.
#229441 - 03/08/2004 08:38 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
No, the builder image wasn't able to format the drive, so it's still unformatted.
#229442 - 03/08/2004 08:47 Re: Unable to format new drive [Re: MattVogt2]
Okay... So you loaded developer on an unbuilt drive? And it worked? I must be missing something - what is your current status / configuration?
#229443 - 03/08/2004 08:53 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
Well, I initially loaded the builder image, but it was unable to format the disk. I was then directed to the manual partitioning-and-formatting notes by Roger - to do this I assumed I need to get a shell on the player. So, I loaded the developer image back onto the player's flash. This image boots, but it is unable to play anything, presumably because it can't find any files to play.
The player image seems fine, as does the visuals application - the only problem is that I don't seem to be able to get the player to quit to let me use the shell.
#229444 - 03/08/2004 08:56 Re: Unable to format new drive [Re: MattVogt2]
Can you hit control-c right just before it starts looking for the player application? Don't wait for the prompt.
#229445 - 03/08/2004 09:04 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
No, hitting Ctrl-C continually doesn't do anything. Either the window of opportunity is too small, or the player isn't receiving any input at all.
#229446 - 03/08/2004 09:10 Re: Unable to format new drive [Re: MattVogt2]
A cheap solution.
You are upgrading from two smaller drives. Make sure you load the 2.0 kernel. Install the original master drive in the player and the new 80GB as the slave. Boot and drop to shell. From here, you will be able to build the new drive using the fully installed kernel from your old master. Just be careful not to destroy the data on the old drive (make sure that all your commands point to the secondary drive, hdc...)
#229447 - 03/08/2004 09:16 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
Hmmm, that's scary.
If I boot from the old master drive, and then drop to the shell, can I disconnect the valid drive before I issue any commands (which might trash the first drive if I get something wrong)?
Or, does the shell need the valid drive to be available for loading commands?
#229448 - 03/08/2004 09:25 Re: Unable to format new drive [Re: MattVogt2]
I think the shell needs the valid drive for the commands to run. Basically, you would need to build the filesystem and all, so that is probably necessary. Either that or do you have access to a Mark2A? There should be enough memory there to finish the build.
#229449 - 03/08/2004 09:28 Re: Unable to format new drive [Re: pgrzelak]
MattVogt2
Ok, I'll give that a shot - I don't have a Mk2a.
Thanks for the advice, I'll let you know how I get on.
#229450 - 03/08/2004 09:48 Re: Unable to format new drive [Re: MattVogt2]
No. Don't try to disconnect the drives when it's running. It needs to load stuff off the disk and it also uses the disk as a swap partition. This is not to mention you could blow something important if you start doing this.
#229451 - 03/08/2004 10:04 Re: Unable to format new drive [Re: tman]
Agreed. Not to mention that you could do very nasty things that way. Leave the hard drive in place. I looked through the instructions, and they are all for doing exactly this - booting from a good master and building a slave drive. Just follow them carefully.
#229452 - 03/08/2004 10:24 Re: Unable to format new drive [Re: pgrzelak]
...'cos that's exactly what I did to put the instructions together.
#229453 - 03/08/2004 11:11 Re: Unable to format new drive [Re: Roger]
MattVogt2
Well, I have made some progress.
First of all, the fact that I couldn't quit out of the player was something to do with hyperterminal not flushing changes; I tried many changes to HT settings, none of which worked, and then eventually after a restart of HT, communication worked again.
Now, I have followed Roger's partitioning+formatting instructions, with the new drive as a slave drive. This worked well, and the player was able to mount and access the new drive correctly. Now, I want to move the new drive to be the master drive (and eventually the only drive), but the player won't boot with the new drive as the master.
It reports:
Kernel panic: VFS: Unable to mount root fs on 03:05
So, my next question is: can the empeg have an 80Gb disk as the master disk?
#229454 - 03/08/2004 11:16 Re: Unable to format new drive [Re: MattVogt2]
Yes. I am running dual 80s.
Now, you partitioned and formatted the drive. Next, remove the original drive, install your 80 as master and reload the 2.0 kernel. This will (or should) pump the partition to populate all of the supporting files.
Edit: Hmmm... Looking through the instruction pages, I saw nothing about making a root filesystem. Roger - is that missing from the instructions?
Edited by pgrzelak (03/08/2004 11:19)
#229455 - 03/08/2004 11:24 Re: Unable to format new drive [Re: pgrzelak]
No, but it could be clearer:
You're done. Put the disk back in the empeg, and install a player image.
#229456 - 03/08/2004 11:31 Re: Unable to format new drive [Re: Roger]
Gah! Too much solaris. I keep expecting the root filesystem on slice 0... Duh... Sorry about that.
#229457 - 03/08/2004 11:35 Re: Unable to format new drive [Re: Roger]
MattVogt2
Yes, that's what it was. I did read that last line, but I thought to myself, I already have a player image on there...
I guess I just didn't realise what 'pumping partition' meant.
Anyway, all's well that ends well. Thanks for your help, everybody.
#229458 - 03/08/2004 15:18 Re: Unable to format new drive [Re: MattVogt2]
Okay, I'm going to use all of the above as an example of the current desperate need to get those builder images updated.
PLEASE SOMEONE AT EMPEG PLEASE MAKE NEW BUILDER IMAGES THAT CAN HANDLE BIGGER DRIVES? PPPPPPLEASE?
#229459 - 03/08/2004 15:30 Re: Unable to format new drive [Re: tfabris]
Had a think about it and we shouldn't need to have the empeg guys do this. The steps required are already on Roger's page so making a new builder image is possible.
I don't have any 80GB drives to test it on however. Only a spare 6GB drive.
Edited by tman (03/08/2004 15:31)
#229460 - 03/08/2004 15:32 Re: Unable to format new drive [Re: tman]
Any volunteers to test it if I make one?
#229461 - 03/08/2004 15:32 Re: Unable to format new drive [Re: tman]
I would be more than willing to exhaustively test it with 100GB drives...
