#229829 - 04/08/2004 06:23 Repair Work
jimmy5
Loc: uk
Is there anyone fixing empegs in the UK..? I have an mk2 player which has problems first a ground has blown; I needed to ground the outside of a audio out plug to stop interference noises from engine, which worked well but needs fixing. 2nd problem is the display started to play up and then gave up totally..! So I had a doggie electrician have a look at replacing internal fuses but he made a mess of the job, now the player is totaly dead only a glowing blue LED..! so I need the unit fixing, can anyone help me..! Thanks Paul…
#229830 - 04/08/2004 06:38 Re: Repair Work [Re: jimmy5]
Er, you wanna post this to the empeg/Troubleshooting section, rather than the Rio Central section.
#229831 - 04/08/2004 06:43 Re: Repair Work [Re: Roger]
jimmy5
Loc: uk
Thanks i will do that.
