#229908 - 05/08/2004 09:37
USB to Serial adapter..
I connecting to my empeg, checking to bootlog after getting one of those USB to Serial adapters... The boot log looks all garbled up. Anyone have any tips on setting one of these up? Is the one I got too slow or something? Running XP, Com8. Here is the boot log: empeg-car bootstrap v1.02 20001106 ([email protected])_chunk_cache_runner.cpp: 294:Filling up space (-21) If there is anyone present who wants to upgrade the flash, let them speak now,cache_runner.cpp: 294:Filling up space (-21) or forever hold their peace...it seems not. Let fly the Penguins of Linux!up space (-21)
e000 v1.04_chunk_cac Copying kernel...:Filling up space Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne) l. spindown_chunk_cache_runner.cpp: 2.95.3 20010315 (release)) #2 Wed Aug 4 00:27:49 EDT 2004 spindown_chunk_cache_runn Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM:_cache_runner.cpp: 294:F c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. spindown_chunk empeg-car player (hardware revision 9, serial number 30102609) 16MB DRAM spindown_chunk_cache_runner.cpp: 294 Command line: mem=16m) Calibrating delay loop... 207.67 BogoMIPS spindown_chunk_cache_runner.cpp: 294:Fi Memory: 15008k/16M available (984k code, 20k reserved, 368k d Linux NET4.0 for Linux 2.2.cpp: 294:Filling up space Based upon Swansea University Computer Society NET3.039 spindown_chunk_cache_runner.cpp: 294:Fill NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP_cache_runner.cpp: 294:Filli TCP: Hash tables configured (ehash 16384 bhash 16384) spindown_chunk_cache_runne IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)
Starting kswapd v 1.5_runner.cpp: 294:Fill SA1100 serial driver version 4.27 with no serial options ena Found custom animation at offset 0x9877cche_runner.cpp: 294:Filling up space (-2 Tuner: loopback=0, ID=-1 Scheduling custom logo.n_chunk_cache_runner.cp empeg display initialised.1) empeg dsp audio initialised spindown_chunk_ empeg dsp mixer initialisedg up space (-21) empeg dsp initialised empeg audio-in initialised, CS4231A revision a0illing up space (-21) empeg remote control/panel button initialised.chunk_cache_runner.cpp: 294:Filling up space ( empeg usb initialised, PDIUSBD12 id 1012 spindown_chunk_cache_runne RAM disk driver initialized: 16 RAM disks of 4096K size spindown_chunk_c empeg single channel IDEing up space (-21) Probing primary interface... hdb: IC25N080ATMR04-0, ATA DISK driveFilling up space (-21) hdb: IC25N080ATMR04-0, ATA DISK drive spindown_chunk_cache_runne hda: HTS548080M9AT00, ATA DISK drive hdb: IC25N080ATMR04-0, ATA DISK drive_cache_runner.cpp: 294:Filling up spa ide0 at 0x000-0x007,0x038 on irq 6 hda: HTS548080M9AT00, 76319MB w/7877kB Cache, CHS=9729/255/63 smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])space (-21)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:3 spindown_chunk_cach 1r Partition check:lling up space ( hda: hda1 < hda5 hda6 > hda2 hda3 hda4 spindown_ch hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4ce (-21) RAMDISK: ext2 filesystem found at block 0chunk_cache_runner.cpp: 294:Filling up sp RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. spindown_chunk_cache_runner.cpp: 294:Filling u EXT2-fs warning: checktime reached, running e2fsck is rec I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: America/Detroit Hijack: intercepting config.ini
hijack: removed menu entry: "Button Codes Display" hijack: removed menu entry: "Button Illumination Level" hijack: removed menu entry: "Font Display" hijack: removed menu entry: "Show Flash Savearea" hijack: removed menu entry: "Volume Level on Boot" hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. ! tags.cpp : 61:Failed to open tags (0xc0041002).
#229909 - 05/08/2004 10:02
Re: USB to Serial adapter..
[Re: SE_Sport_Driver]
Are you capturing to a file? Many times, screen buffer captures tend to show this kind of thing.
#229910 - 05/08/2004 10:59
[Re: pgrzelak]
I agree with Paul. Capture to a file. Ditch hyperterminal if possible too. I'm guessing you are using cut and paste using hyperterminal.
This seems to happen quite often on boot log captures for some reason - probably the 115200 baud with no flow control doesn't help eventhough the average PC should be able to hand those kind of data rates.
Edit:
Oh and we use a large number of these USB-serial adapters quite successfully.
Looking at the log, it seems it's overwriting things. You can see player messages at the very beginning of log well before the player even starts.
Edited by Shonky (05/08/2004 11:09)
#229911 - 05/08/2004 11:09
[Re: Shonky]
Quote: This seems to happen quite often on boot log captures for some reason - probably the 115200 baud with no flow control doesn't help eventhough the average PC should be able to hand those kind of data rates.
No, it's because, in contrast to the ones supplied with earlier versions of Windows, XP Hyperterminal is hopelessly, unusably, QA-clearly-didn't-even-run-it-once buggy. Get PuTTY or Teraterm instead.
#229912 - 05/08/2004 14:49
[Re: peter]
Thanks everyone.
Not to sound terribly cheap.. but are any of those free? And if not, is there one you prefer for "empeg" type uses?
#229913 - 05/08/2004 14:53
[Re: peter]
PuTTY is IIRC...
#229914 - 05/08/2004 15:35
[Re: genixia]
Teraterm is as well
#229915 - 05/08/2004 15:36
[Re: peter]
Quote: Get PuTTY or Teraterm instead.
There's a version of putty that'll work on a serial connection? AFAIK there isn't, but I'd be happy to hear that there is.
#229916 - 05/08/2004 15:41
[Re: matthew_k]
Hmm. Yeah. Just ran it and it doesn't seem to support serial. I use SecureCRT for SSH and serial and it works great but it is expensive.
#229917 - 05/08/2004 17:00
[Re: matthew_k]
Teraterm works well. PuTTY does not ( yet?) support serial connections.
#229918 - 05/08/2004 19:17
Quote: PuTTY does not (yet?) support serial connections.
Yeah, that's been there since the last My Terminal Program Is Better Than Your Terminal Program discussion. I wish they'd implement it, Putty is great otherwise. (All it needs is a config-file-instead-of-the-registry setting so it'll work perfectly off my flashdrive)
#229919 - 05/08/2004 19:24
[Re: tman]
TeraTerm Pro is working great! Thanks guys!
#229920 - 05/08/2004 19:26
[Re: tman]
Quote: SecureCRT
I've been using the VT100 fonts that came with that for years now, long after my version of SecureCRT became obsolete. I keep them on my USB flash drive, even.
