#230244 - 09/08/2004 11:48 Audivox/Sirius tuner install
edsmiata
Loc: New Jersey
Recently installed the Audiovox Sirius tuner in the car and instead of the FM Mod i ran rca's to the aux in...now i get severe ignition noise...static and whine...i am confidant that it is leaking in through the cig lighter adapter...
anybody else experience this, and if so, what is the best way to solve it?
Ed
edit : fixed title.
-l0ser
Edited by l0ser (09/08/2004 18:16)
#230245 - 09/08/2004 11:50 Re: Audivox/Sirius tiner install [Re: edsmiata]
Where is your Sirius tuner getting power / ground from? You probably need to have them all at the same level / source. If it is the lighter adapter, that is probably a very noisy source...
#230246 - 09/08/2004 12:00 Re: Audivox/Sirius tiner install [Re: pgrzelak]
edsmiata
Loc: New Jersey
Paul,
Agreed....however...i understand that the cig plug steps down the voltage from 12 to 6....otherwise i think they would have offered the hardwire option...
i tried putting a ground loop isolater in the path..but it literally killed the signal
Crutchfield suggested that i wire the cig lighter plug into the wiring of the head unit...as you allude to...and i think that is the way it will have to go
i was just wondering if in fact anybody had actually done this...
Ed
#230247 - 10/08/2004 15:17 Re: Audivox/Sirius tuner install [Re: edsmiata]
Please try grounding the RCA cable shields. This was a known issue with the Aux-in of some players.
#230248 - 11/08/2004 17:13 Re: Audivox/Sirius tuner install [Re: tfabris]
edsmiata
Loc: New Jersey
Tony,
So i would just solder some ground wire to the shields and ground them to the chassis?
#230249 - 11/08/2004 18:03 Re: Audivox/Sirius tuner install [Re: edsmiata]
Precisely.
