#236100 - 30/09/2004 18:51 Any place for cheap mini-itx cases?
trs24
I'm looking for a mini-itx cube style computer case - like the shuttle case. I need a cube because I need to be able to use a full size pci card in it. But I can't seem to find one that isn't more expensive the the mini-itx mobo.
Does anyone know a good source for inexpensive computer cases that fit that form factor?
- trs
#236101 - 30/09/2004 18:56 Re: Any place for cheap mini-itx cases? [Re: trs24]
robricc
#236102 - 30/09/2004 19:02 Re: Any place for cheap mini-itx cases? [Re: trs24]
http://www.mini-itx.com/store/default.asp?c=3#p9
Has cube cases just cheaper than the mobos.
#236103 - 30/09/2004 19:20 Re: Any place for cheap mini-itx cases? [Re: andy]
trs24
Thanks guys. Those are about the same price ranges I had found previously. I suppose I could go with a slim form factor rather than a cube, too. But than I'd have to get a $20, or so, pci riser to turn the pci card 90 degrees. Either way it looks like it'll be around $100 for a case. Ugh.
- trs
#236104 - 01/10/2004 18:43 Re: Any place for cheap mini-itx cases? [Re: trs24]
Some of the cases *include* the PCI riser card as a standard included accessory.. read the fine print.
