#238554 - 21/10/2004 17:55 Intermittent Problem with Upgraded Player
gb14772
I upgraded my 36GB 2-drive player to a ~100GB 2-drive player by replacing an 18GB IBM drive with an 80GB Toshiba drive. I did manual formatting and copying and all was well.
Now, I intermittently get a screen message "No hard disk found" or something like that. Power down/up, sometimes four or five times, and all is well again.
I've checked cable connections, jumpers, I've recrimped the cable, checked solder joints.
Any suggestions? Is there a known serial number range that has "dodgy cables"? My S/N is 080000480. Other than the cable, all I can think of is the IBM drive doesn't play nice with the Toshiba drive...
Any suggestions?
Here's part of the console output when it fails:
Vcb: 0x4054d000
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000480) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff '˙˙˙˙'
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel but
empeg state support initialised 0089/88c1 (save to d0004e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: TOSHIBA MK8025GAS, ATA DISK drive
hdb: TOSHIBA MK8025GAS, 76319MB w/0kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:e
0
Partition check:
EXT2-fs warning: checktime reached, running e2fsck is recommende
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...rnel panic: VFS: Unable to mount root fs on 03:05
Note that it can't seem to find the IBM drive on hda. When it was failing, I did unplug only the Toshiba drive (2nd drive postion), and it did boot up fine and could find the IBM drive.
thanks for any help/advice.
-gbeck
#238555 - 21/10/2004 18:01 Re: Intermittent Problem with Upgraded Player [Re: gb14772]
Daria
Bad (loose) slave jumper on the second drive?
#238556 - 21/10/2004 18:13 Re: Intermittent Problem with Upgraded Player [Re: Daria]
gb14772
Checked the slave jumper already, even replaced it with a different one. Don't think that's it. But thanks for the suggestion.
-gbeck
#238557 - 21/10/2004 18:17 Re: Intermittent Problem with Upgraded Player [Re: gb14772]
Usually that's an all-or-nothing thing, if I recall correctly.
You could try plugging in just one drive or the other, testing each extensively.
#238558 - 21/10/2004 18:30 Re: Intermittent Problem with Upgraded Player [Re: gb14772]
Daria
I only thought of it due to experience
My jumper is now taped on.
#238559 - 21/10/2004 18:37 Re: Intermittent Problem with Upgraded Player [Re: Daria]
gb14772
I just realized I have a backup Empeg from the Rio fire sale. Moved the cable from the backup unit, still fails. Then put drive sled into the backup unit, still fails. So whatever it is must be the drives. Each drive does work fine by itself.
My next step will probably be to replace or just get rid of my smaller drive. Is there a quick way to move it's data and merge it with my new second drive (that already has stuff on it)?
thanks.
-gbeck
#238560 - 21/10/2004 19:12 Re: Intermittent Problem with Upgraded Player [Re: gb14772]
Hm. Each drive works singly, but it fails intermittently when they are together?
Any chance it's an AC adapter not supplying enough juice? Got a spare adapter to try?
#238561 - 21/10/2004 19:14 Re: Intermittent Problem with Upgraded Player [Re: gb14772]
Yes, I believe specific instrucations are even covered in the drive upgrade guide. The contents of the FIDS folder on each drive can be combined into one folder on the drive you want to keep. In theory, if the files aren't messed up and the fids didn't come from two separate players, there shouldn't be any overlap in the files.
#238562 - 22/10/2004 01:22 Re: Intermittent Problem with Upgraded Player [Re: tfabris]
gb14772
I replaced my 18GB IBM Travelstar drive with the 20GB Fujitsu drive from my backup Empeg, and copied everything over. So far, it's working fine. It will take a week in the car to verify.
Looks like the IBM drive doesn't play nice with the newer Toshiba drive.
Thanks for the help and advice.
-gbeck
