#240128 - 04/11/2004 13:05 Tuner Issue
mafisto
Loc: St. Paul, MN, USA
I have a MkIIa with an original tuner, and am experiencing something odds (and have been for a year): the tuner does not tune. It moves between presets with the left/right button, but doesn't incrementally move up and down the dial.
I'm sure I accidentally hit a setting somewhere that forces the tuner to only move between presets, but surely there's a way to switch it back?
your fiend, mafisto
#240129 - 04/11/2004 13:09 Re: Tuner Issue [Re: mafisto]
The tuner controls don't normally work the way one might expect them to. But the v3alphas make it worse, in that some of the tuning functions there are broken (not working).
To manually tune up/down on the "dial", use the Hijack KnobSeek function. This does *exactly* what you want.
#240130 - 04/11/2004 13:15 Re: Tuner Issue [Re: mlord]
mafisto
It's been a year since my last software update (or has it been two) and it never occurred to me that a feature would stop working... duh. I should probably update anyway, so thanks for the kick in the pants.
your fiend, mafisto
#240131 - 04/11/2004 15:54 Re: Tuner Issue [Re: mafisto]
Mafisto, please note that all tuner functions in relation to the button controls are described here. You can move incrementally up and down the dial if you use the remote control. (The functions are labled as "Tuner: Increment Frequency" in the button guide.)
The feature that broke was the scan for next strong frequency. That bug is described here in a new FAQ entry I just created because I realized there had been some other questions about that feature here recently.
#240132 - 05/11/2004 09:45 Re: Tuner Issue [Re: mlord]
jarob10
Loc: Stockport, UK
Can anyone confirm the most recent software release which has a fully operational tuner? I was gonna upgrade to 3.0 for this reason (following a planned memory upgrade).
#240133 - 05/11/2004 11:51 Re: Tuner Issue [Re: tfabris]
Was Enqueue in beta 13?
I love that feature
#240134 - 09/11/2004 02:06 Re: Tuner Issue [Re: jarob10]
2.0 Beta 13.
Not sure about 3.0 alphas, but I'm guessing you won't be using 3.0 for more than just some experimentation. It's got enough bugs still that it's probably not suitable as a daily driver.
Note that 3.0 is not required for the memory upgrade, there is a 2.0 build that incorporates expanded memory support. However, since it's based on 2.0-final, it will include the bug described in that FAQ entry.
Yes.
#240135 - 11/11/2004 17:08 Re: Tuner Issue [Re: tfabris]
Derek
Loc: NRW, Germany
I'm using a 3.0 beta and have a stock tuner. It's all working fine.
