#243333 - 05/12/2004 15:17 empeg not holding settings, please help!!!
farmtech
Hello, my empeg (MK2A) is giving me a headache. I just installed it in a 03 Tahoe after it sat on the shelf for 3 months. When I first powered it on it said "Player Settings Lost" and would continue to do this on every boot until I performed a reboot through Hijack. It now seems to boot up correctly but all settings are lost, (clock, current song, volume, etc.) I opened up the unit and checked the super cap on the board and it was 3.42V. Is this the source of my problems? How does the memory system work? I have constant power wired up to the sled as well as switched. Any help would be greatly appreciated.
Nick
#243334 - 05/12/2004 15:42 Re: empeg not holding settings, please help!!! [Re: farmtech]
The cap is just used for the RTC. The actual settings are stored in flash which doesn't need any power to retain the data. As to why you lost the settings *shrug* it shouldn't have worn out yet unless you've been sitting there rebooting it a few million times. Something must have corrupted the setting.
#243335 - 05/12/2004 17:04 Re: empeg not holding settings, please help!!! [Re: tman]
Agreed. First thing is you need to apply a fresh build of 2.0 final software, pure, and see if that solves the problem.
#243336 - 05/12/2004 17:58 Re: empeg not holding settings, please help!!! [Re: tfabris]
farmtech
Ok, I will give that a try and let you know what happens.
Thanks.
#243337 - 05/12/2004 21:20 Re: empeg not holding settings, please help!!! [Re: farmtech]
farmtech
Ok, I just got finished using the Rio upgrade wizard. It seems to have upgraded just fine, I now have the RIO splash screen and my Hijack is gone. I still am not able to retain any settings or clock. When I plug the AC adapter in it starts with the same song every time in pause mode I can start the song playing, forward to a different song and set the volume but as soon as I unplug the power supply and plug it back in every thing resets. Now what???
#243338 - 06/12/2004 18:09 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Losing Hijack is expected - just grab the latest version and reapply it using logoedit.
The lost settings thing is a real problem. The player relies on energy stored in its power supply capacitors to write the flash when the power fails. I suspect that perhaps one of these has gone bad.
#243339 - 06/12/2004 23:52 Re: empeg not holding settings, please help!!! [Re: genixia]
farmtech
I have my Empeg apart and I think the power supplies are functioning correctly. I even temporarily added an extra 220uF of capacitance in parallel with 3 blue caps on the input of the switching fets, no help. I then moved the 220uF cap to the 3 yellow surface mount caps at the back edge of the board this was the 3.3V supply (I would think this is what the flash would use but not for sure) this had no effect either. I also tried moving it to the two 5V caps and the 2.0V processor core cap all with no effect. I am starting to think that one of two things is happening. (1) the processor is not seeing the power supply go down (this probably happens by the processor looking at a voltage sense line somewhere on the board or (2) the application is somehow still corrupt and it is not looking for the shutdown signal.
I just don't understand this because this thing has worked perfect since I bought it but after setting on the shelf for 3 months is now not working. I should say that the entire time I had it in my previous car it would power up in standby about 1/2 of the time and I was never able to figure it out.
Does anyone think it would be worth wiping out the kernel and app and starting completely over? If so how would I do that.
Very puzzled and sad
#243340 - 07/12/2004 00:21 Re: empeg not holding settings, please help!!! [Re: farmtech]
If I'm not mistaken, the "player settings lost" does not indicate a capacitance problem. If the player doesn't save its settings properly, it merely uses the last settings in flash.
No, I think the "player settings lost" error indicates worse trouble with either the kernel or the flash itself. Just for the heck of it, do a RAM test, too (the ctrl-T thing in the hyperterminal section of the FAQ).
#243341 - 07/12/2004 00:58 Re: empeg not holding settings, please help!!! [Re: tfabris]
farmtech
Well, here it what it said....
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IBM-DARA-212000
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 26
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
Just to clarify, the first 3 times I applied power after the install it said "player settings lost" but then after doing a reboot through Hijack it powers up fine with no warnings but the settings are always back to defaults.
#243342 - 07/12/2004 02:52 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Can you post 3 boot logs? Leave the serial connected between boots. Do a full power down reboot, not hijacks reboot feature.
#243343 - 07/12/2004 12:36 Re: empeg not holding settings, please help!!! [Re: genixia]
farmtech
Sure I can, by "full power down reboot" do you mean just pulling the AC adapter when it is playing and then plugging it back in?
#243344 - 07/12/2004 14:15 Re: empeg not holding settings, please help!!! [Re: farmtech]
schofiel
If this is only happening in the car sled, then I would check out the fuse on the supply lead.
#243345 - 07/12/2004 14:34 Re: empeg not holding settings, please help!!! [Re: schofiel]
farmtech
This happens in the car and in the house. For now I am just using the AC adaptor on the back of the Empeg, I can play a song, pull the cord out and when I plug it back in every thing has reset. I do not see any error messages but I will post 3 boots tonight.
#243346 - 07/12/2004 14:35 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Yes.
#243347 - 07/12/2004 20:11 Re: empeg not holding settings, please help!!! [Re: farmtech]
schofiel
More useful: blow V2 Developer. From the command line discard the current playlist and start the player from scratch with "player -i" (see the FAQ for this). Then reboot, connect with emplode, change one single piece of data, then do a sync.
#243348 - 08/12/2004 03:28 Re: empeg not holding settings, please help!!! [Re: schofiel]
farmtech
Sorry but I do not understand what you mean by "blow v2 developer", I searched the FAQ for this and "player -i" with no results. The boot messages look normal but here is what I received when I captured three complete boots with Hyperterminal.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 120001063)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N0
serial_notify_thread.cpp: 117:@@ F0x14e0
serial_notify_thread.cpp: 118:@@ TBamboo
serial_notify_thread.cpp: 119:@@ AJoe Satriani
serial_notify_thread.cpp: 120:@@ GOther
serial_notify_thread.cpp: 180:@@ #0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
e000 v1.04
Copying kernel...
Partition check:
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
Partition check:
Freeing unused kernel memo player.cpp : 385:empeg-car 2.00 2003/04/01.
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #14e0 0:00:00
#243349 - 08/12/2004 04:48 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Rob meant to put the v2-developer build on your player, then 'Q' or Ctrl-C your serial port after it finishes booting, and then run the player with its "Ignore all our existing saved data" flag. I don't think that it will help you, unless it also resets the flash save-area to the default too.
Is There Love In Space? Who knows? Anyway, your player is certainly not saving its state correctly:
The "save to" address should change at each boot. The fact that is the same each time indicates that the flash is not being written correctly at shut down, for whatever reason.
There is a debug flag in the kernel that could be compiled in that prints "The Quick Brown Fox..." at shutdown. The empeg guys put it in so that they could measure how long the power stays up (to ensure that the flash did indeed get written, no less). I'm not really sure what is considered normal though.
#243350 - 08/12/2004 12:09 Re: empeg not holding settings, please help!!! [Re: genixia]
farmtech
Ok, I installed the V2 developer version, and ran "player -i" from the shell prompt. It did reset my playlist but did not fix my problem. Posted below is a what Hyperterminal captured when I advanced a few tracks, adjusted the volume up a little and then pulled the AC cord and restarted. It is still not writing correctly to the flash area. Is it possible that the flash save area is corrupt? Can I view it or erase it?
serial_notify_thread.cpp: 116:@@ N1
serial_notify_thread.cpp: 117:@@ F0x730
serial_notify_thread.cpp: 118:@@ TGnaah
serial_notify_thread.cpp: 116:@@ N2
serial_notify_thread.cpp: 117:@@ F0x950
serial_notify_thread.cpp: 118:@@ THands in the Air
serial_notify_thread.cpp: 116:@@ N3
serial_notify_thread.cpp: 117:@@ F0x10b0
serial_notify_thread.cpp: 118:@@ TIf I Could Fly
serial_notify_thread.cpp: 116:@@ N4
serial_notify_thread.cpp: 117:@@ F0x1100
serial_notify_thread.cpp: 118:@@ TI Like the Rain
serial_notify_thread.cpp: 116:@@ N5
serial_notify_thread.cpp: 117:@@ F0x1090
serial_notify_thread.cpp: 118:@@ TIs There Love in Space
serial_notify_thread.cpp: 116:@@ N6
serial_notify_thread.cpp: 117:@@ F0x10e0
serial_notify_thread.cpp: 118:@@ TJust Look Up
serial_notify_thread.cpp: 170:@@ S1
serial_notify_thread.cpp: 136:@@ V1
serial_notify_thread.cpp: 136:@@ V2
serial_notify_thread.cpp: 136:@@ V3
serial_notify_thread.cpp: 180:@@ #10e0 0:00:02
serial_notify_thread.cpp: 136:@@ V4
serial_notify_thread.cpp: 136:@@ V5
serial_notify_thread.cpp: 136:@@ V6
serial_notify_thread.cpp: 136:@@ V7
serial_notify_thread.cpp: 180:@@ #10e0 0:00:03
serial_notify_thread.cpp: 180:@@ #10e0 0:00:04
serial_notify_thread.cpp: 180:@@ #10e0 0:00:05
serial_notify_thread.cpp: 180:@@ #10e0 0:00:06
e000 v1.04
Copying kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
Partition check:
Press Ctrl-A to enter pump... hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Vcb: 0x4086d000
#243351 - 09/12/2004 05:59 Re: empeg not holding settings, please help!!! [Re: farmtech]
schofiel
Although you have blown V2Dev and reset the playlist, you did not connect with emplode and modify a playlist followed by a sync.
If your flash was corrupt/damaged/whatever, then the player app would not load.
Have you performed any modifications (hardware or software) to the player recently?
#243352 - 09/12/2004 12:38 Re: empeg not holding settings, please help!!! [Re: schofiel]
farmtech
I have not done any modifications to the empeg itself ever, I did make a device that monitored the serial notify info coming out of the serial port in order to indicate if the empeg was in aux or player mode. (This was needed for my previous installation) The empeg was running V2 and Hijack 379 before getting pulled out of my car and sitting on the shelf for 3 months.
The first time I powered the empeg on after sitting 3 months it said "player settings lost" so maybe that is a clue???
I will try modifying a playlist and re-synching tonight.
Nick
#243353 - 09/12/2004 23:12 Re: empeg not holding settings, please help!!! [Re: farmtech]
farmtech
Ok, I just reset my playlist using "player -i" I then connected to emplode, added a new playlist put 3 songs in it and resynched. My problem still exists, the empeg will reset and go back to the first song in the playlist in pause mode when power is removed. What next?
Does anyone know which GPIO pin the processor uses to monitor the power supply?
Nick
#243354 - 09/12/2004 23:50 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Throw this kernel on your player and let's see the serial output from a couple of boot/power down sequences.
#243355 - 10/12/2004 00:06 Re: empeg not holding settings, please help!!! [Re: genixia]
farmtech
Cool, I am willing to try anything, however I am not sure how to load just the kernel. Is there something described in the FAQ or can you give some quick instructions?
Thanks for the help
Nick
#243356 - 10/12/2004 00:13 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Download Logoedit. You'll find a kernel flashing utility there.
#243357 - 10/12/2004 00:38 Re: empeg not holding settings, please help!!! [Re: genixia]
farmtech
Sorry about that, I knew that. I am not thinking straight tonight for some reason. Here is what I came up with...
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 ([email protected]) (gcc version 2.95.3 20010315 (release)) #3 Thu Dec 9 20:42:29 EST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 120001063) 16MB DRAM
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Powerfail is now disabled (1)
Powerfail is now enabled (0)
Tuner: loopback=0, ID=-1
Powerfail line current level is 0
empeg state support initialised 0089/88c1 (save to d0004180).
Partition check:
Mounting proc
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #1090 0:00:00
serial_notify_thread.cpp: 180:@@ #1090 0:00:01
serial_notify_thread.cpp: 180:@@ #1090 0:00:02
serial_notify_thread.cpp: 180:@@ #1090 0:00:03
serial_notify_thread.cpp: 180:@@ #1090 0:00:04
serial_notify_thread.cpp: 180:@@ #1090 0:00:05
serial_notify_thread.cpp: 180:@@ #1090 0:00:06
serial_notify_thread.cpp: 180:@@ #1090 0:00:07
serial_notify_thread.cpp: 180:@@ #1090 0:00:08
e000 v1.04
Copying kernel...
Partition check:
Mounting proc
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #950 0:00:00
#243358 - 10/12/2004 01:43 Re: empeg not holding settings, please help!!! [Re: farmtech]
This might be normal/expected behavior depending on how many songs are in that playlist.
This is a completely different issue than the "Player Settings Lost" error you described before. Are you still getting that error or not?
#243359 - 10/12/2004 01:54 Re: empeg not holding settings, please help!!! [Re: tfabris]
farmtech
I only have 3 songs in that particular playlist. I think I only have around 1000 songs in the player total.
When I first powerered on the empeg after sitting 3 months it said "player settings lost" I pulled power 2 or 3 times and it kept saying "player settings lost". I then went into the Hijack menu and did a reboot player. I have not seen the "player settings lost" since but I am not able to retain settings or the time from the RTC.
Wierd huh.
#243360 - 10/12/2004 03:39 Re: empeg not holding settings, please help!!! [Re: farmtech]
genixia
Hmm. no evidence that the power fail event was seen. As far as I can tell, we should have seen a serial message...
However, I'm not sure whether the serial notify feature may be clobbering it - or at least delaying it until the power is totally dead.
Can you set "suppress_notify=1" in the hijack section of your config.ini and try again.
#243361 - 10/12/2004 11:03 Re: empeg not holding settings, please help!!! [Re: farmtech]
schofiel
I wonder if the leaf spring in the DC power socket has failed into the on state?
Can you move the leaf with a matchstick or something?
#243362 - 10/12/2004 11:59 Re: empeg not holding settings, please help!!! [Re: schofiel]
farmtech
Ok, I set suppress notify = 1, now the player starts up and goes into standby mode every time. The last 2 powerfail statements in the boot cycle happen once I turn the empeg on after it has booted up. I can check the leaf spring in the power connector but I am pretty sure it is fine, the connector does not get used much.
Here it is, 2 boots.
e000 v1.04
Copying kernel...
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg state support initialised 0089/88c1 (save to d0004200).
Partition check:
Mounting proc
Press 'q' now to go intStarting player
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
Partition check:
Mounting proc
Vcb: 0x4086d000
