#243453 - 06/12/2004 18:05 I feel like an idiot...need Tuner help
huberse
Hi to all out there, i know that this sounds real stupid.....but i finished my Tuner Kit. I think it's working, but HOW can i tune the stations or could this be a failure in assembly of the tuner. Thanks for any help
proud owner of a Mk2A.... one of the latest in stores :-)
Built into an 94' Audi 100 S4 4.2 quattro -= 300 HP and Linux in it =-
feels great !
#243454 - 06/12/2004 19:51 Re: I feel like an idiot...need Tuner help [Re: huberse]
Please be more specific.
Do you mean that you can't switch to the radio at all? Make sure you have the version 2.0something software, because some of the 1.somethings didn't have tuner support.
If you have 2.0something and you don't have a "Radio" menu on the main menu, then it might be a fault in the assembly. The tuner should be automatically detected and you should get a Radio menu.
If you mean that you have trouble with scanning for the next station, click here.
#243455 - 06/12/2004 20:01 Re: I feel like an idiot...need Tuner help [Re: tfabris]
Ezekiel
Loc: NH USA
Tony,
Pardon my ignorance, but was that fixed in the 3.0 alphas? I'm still running 2.0 Final on both my players.
-Zeke
WWFSMD?
#243456 - 06/12/2004 20:27 Re: I feel like an idiot...need Tuner help [Re: tfabris]
Uh, isn't it under the "Source" top-level menu?
#243457 - 06/12/2004 21:49 Re: I feel like an idiot...need Tuner help [Re: wfaulk]
I meant that all the radio functions are in the radio menu once you switch to the radio. I figured he'd found the "Tuner" button on the remote already, and if he hadn't, the links from that FAQ entry would have pointed him to it.
#243458 - 07/12/2004 03:27 Re: I feel like an idiot...need Tuner help [Re: huberse]
huberse
Hi Tony,
the tuner is recogniced, so i'm thinking that i have the problem with the Bug. Will try it with the direct frequency input but have to buy a battery first for the remot....what a shame, i never used it. Thanks for the link to the Button guide. Was searching nearly an hour trough the FAQ's but diden't saw it. I let you know if it's working then.
regards Serge
feels great !
#243459 - 09/12/2004 03:31 Re: I feel like an idiot...need Tuner help [Re: huberse]
huberse
Thanks Guy's
that did it - it's the BUG. I can listen to Radio now but i'm going to resolder the HF Cable ( like described here in the board ) cause the Signal is not that good as it should.
Many thanks and regards
Serge
feels great !
#243460 - 10/12/2004 01:39 Re: I feel like an idiot...need Tuner help [Re: huberse]
In addition to that, also click here and here to read about other things that might cause the signal to be low.
