#246484 - 13/01/2005 16:14 Glovebox install in Audi S4
kday
Loc: Boston, MA
See attached photo.
I like this setup a lot. For maximum stealth the stock head unit is used, with the empeg's output routed to the CD changer input. The amp remote line on the empeg triggers a relay which switches out the CD changer whenever the empeg is turned on.
#246485 - 14/01/2005 14:51 Re: Glovebox install in Audi S4 [Re: kday]
SE_Sport_Driver
How do you control it?
#246486 - 14/01/2005 15:54 Re: Glovebox install in Audi S4 [Re: SE_Sport_Driver]
kday
Loc: Boston, MA
Currently I'm using the remote. It works okay; the hard part is navigating playlists while moving, since the display is tough to see while watching the road. I typically don't change playlists while moving, just forward and shuffle.
I am working on a small remote display and button panel. It will get done eventually.
#246487 - 15/01/2005 16:32 Re: Glovebox install in Audi S4 [Re: kday]
FireFox31
Loc: East Coast, USA
Glovebox installs seem like a great solution for cars with integrated factory stereos. I hope the remote display project picks up enough to make this more feasible. Imagine going into stealth mode by simply removing the remote display that's suction-cupped to your dashboard.
FireFox31
