#248526 - 04/02/2005 19:53 MINI p3 1.2Ghz 512Meg 80G SHuttle PC
belezeebub
This was my Proto-Type System.
Seeing my P4 system has become my FreeVo because it used to much Power I am switching to a low power Via for my second attempt at a car computer
$300.00 Plus Shipping
P-3 1.2Ghz,
512MB's of Ram,
80GB Maxtor hard drive,
3½" floppy drive and a
CyberDrive 40x16x48 CD-RW.
It comes with Nero 5.5 Express CD.
I have a Unused OEM cert from my old dell that is running Rehat so I will toss in the ME cert and a burned Desk I lost the restore disk a long time ago (good think I make os cd's)
There are a few scuff marks on the side of the case, but this system is
100% operational.
Shuttle Pentium III Tualatin
XPC Mini System
CPU
Socket 370 All Intel Pentium III and Celeron Processors (including Tualatin)
Onboard Features
Memory DIMM x 2, up to a total of 1GB (max) memory size, 168-pin PC100 /PC133 SDRAM
Graphics Built in Savage 4 graphics engine
Audio VIA audio with AC'97 CODEC
Onboard 1394 Firewire Chipset VIA VT6306, supports 400Mb/s, 200Mb/s, 100Mb/s data transfer rate
Ethernet On board Realtek 8100B 10 Mb/s and 100 Mb/s operation
Expansion Bus 1 x PCI. PCI 2.2 specification compliant
Built in VIA 686B Support 1 UART for Complete Serial Ports
Support 1 Multi-mode parallel port
Support 1 Floppy Disk Controller
Support PS2 keyboard and mouse
H/W Monitor Built in VIA686B Voltage, Temperature, Fan Speed Monitor
IDE Ultra DMA 33/66/100 mode
PIO mode 4
2 IDE ports
Power Management APM 1.2 ACPI 1.0
BIOS Award PnP BIOS DMI 2.3 2Mb flash memory
BIOS Functions CPU Voltage Auto Detecting (CPU PnP)
Support Suspend to Ram
Power on by Ring
Back Panel Ports and Connectors
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA port
1 x Serial Port
1 x Parallel port, supports SPP, ECP, and EPP mode
2 x 1394 ports
1 x S-Video connector
1 x Composite connector
2 x USB ports
1 x RJ45 port
1 x line-in connector
1 x line-out connector
Other Connectors and Jumpers
2 x Fan connectors
2 x Front Panel USB Connector Header
1 x Front Panel line-out and mic-In Header
1 x CD Audio in connector
1 x Clear CMOS
1 x ATX power connector
Case
Material Aluminum
Dimensions 190 W x 170 H x 270 D mm
7.5 W x 6.7 H x 10.6 D Inches
Edited by belezeebub (04/02/2005 19:54)
#248527 - 08/02/2005 18:06 Re: MINI p3 1.2Ghz 512Meg 80G SHuttle PC [Re: belezeebub]
belezeebub
Heck make it 275 (I need to buy a new tuner card for my freevo
______________________________________ Do not meddle in the affairs of Network Administrators, for they are subtle and quick to anger. ______________________________________ Worlds Lamest Wb Site (mine) http://home.comcast.net/~jlipchitz/
#248528 - 09/02/2005 19:54 Re: MINI p3 1.2Ghz 512Meg 80G SHuttle PC [Re: belezeebub]
SonicSnoop
Loc: Triangle, VA
Sent an email.
#248529 - 10/02/2005 17:01 Re: MINI p3 1.2Ghz 512Meg 80G SHuttle PC [Re: SonicSnoop]
belezeebub
Computer is sold.
