#248580 - 07/02/2005 03:58 Windows XP, Jreceiver and RioBoot - looking for alternate boots
rembrandt
I have a windows xp platform running jreceiver 0.2.5. using rioboot. Currently I am using rioplay .29a2 instead of reza's client, because its faster and doesnt hang up as much.
Previously I had a linux server, and used trio - that machine crashed and burned, and due to work reasons, i can't go that route again. [i need the box this server is on to be a windows box.]
My only real issue atm with rioplay is that it plays tracks in alphabetical order (not track number) and that there is no random button. [all the other limitations i can live with.]
I do mis the receiver synch that trio had .. as i have 4 of these damn things [used to be great when we threw parties]
My questions are :
1) is there an alternate bootloader that I can use with rioboot that is fast, and will play tracks in the order they are reced from jrec
or
2) is there any docs for using trio 1.6 with my config ?
I noticed on the trio site that they say it doesn't work with rioboot atm. but there was some (very confusing looking) workaround .. is there a stepthrough, or does anyone have any experience with this ?
I thank you all in advance.
#248581 - 07/02/2005 09:07 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: rembrandt]
vince
Why not use arm to boot the rios?
Before moving to linux/trio/jrec I had Windows/trio/arm, you'd just have Windows/trio/jrec/arm
Vince
Vince, UK RioCar 20GB + 20GB, tuner & stalk, 5 x Audio Receivers
#248582 - 07/02/2005 11:56 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: rembrandt]
drule
tRio can be made to play with RioBoot. When you expand the receiver.arf file that comes with the riot-x.y.z package on a Windows machine you'll get a load of errors. These are down to symbolic-links which aren't supported on either FAT or NTFS. The work around is to make multiple copies of the actual files and name them with the symbolic names.
For example, in the bin directory there appears to be 76 files but in fact there are only 6 files (bash, busybox, lcd, ldd, nc & sh), and 70 symlinks; all of which point to busybox. So, in this directory you need to make 70 copies of busybox and name them: basename, cat, chgrp, chmod, chmod, ..., etc. Do this for each of the directories and voila! It's a bit of a kludge but I can assure you it works. I've got this going on both XP and Windows 2003.
-DR
#248583 - 07/02/2005 12:09 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: drule]
rembrandt
Thats a pretty clever kludge
not being in front of the home computer atm .. how can i tell which is a file and whilch is a symlink ?
and is there a better program to expand tar? i used winrar with the arf that came with the rio .. and it went nuts when i tried to connect to it.
#248584 - 07/02/2005 17:37 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: rembrandt]
drule
WinRAR seems to do the job perfectly except for one error (see below). I originally untar'ed receiver.arf on a linux box and WinSCP'ed the files back over.
Looking at it again, I see that there's a symlink ../tftpboot/default/dev/core that points to /proc/kcore (this is where the WinRAR error occurs). That's /proc off the Linux root not the proc directory under tftpboot which is empty. I made a copy of /proc/kcore as ../tftpboot/default/dev/core and it works fine but I was just wondering what riot is using this file for since it is 270MB?
I'd like to post a zip of riot for RioBoot users but having to include this file would make it too big.
Dave
#248585 - 08/02/2005 00:36 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: drule]
rembrandt
OK .. with the arf set as default in my reioboot/tf* dir
and with core put in /dev
I can start up trio
start up jreceiver and the nfs and portmapper software for rioboot
i can stream to winamp.
when i try to start my receiver .. i get looking fo server .. connectiong to server (the nfs goes nuts eventually rebooting with the following appearing in the nfs window.
im so close i can taste it.
et
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4915
20 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 4096 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4956
16 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4997
12 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 8192 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5038
08 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 12288 offse
t
NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.cache
NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 114688 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 118784 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 122880 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 126976 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 131072 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 135168 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 139264 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 143360 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 81920 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 86016 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 90112 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 94208 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 147456 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 151552 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 155648 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 159744 offs
et
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6062
08 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6103
04 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6144
00 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6184
96 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5898
24 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5939
20 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5980
16 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6021
12 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8355
84 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8396
80 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8437
76 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8478
72 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2949
12 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2990
08 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3031
04 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 65536 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3072
00 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 69632 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 73728 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3112
96 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 77824 offse
t
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3194
88 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3235
84 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3153
92 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5734
40 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5775
36 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5816
32 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2785
28 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5857
28 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2826
24 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2867
20 offset
NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\fstab
NFS read C:\Program Files\rioboot\tftpboot\Default\etc\fstab,4096 bytes 0 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2908
16 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2457
60 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3768
32 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2498
56 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2539
52 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3809
28 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2580
48 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3850
24 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3891
20 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2621
44 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6389
76 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2662
40 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2703
36 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6430
72 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2744
32 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6471
68 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6512
64 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6553
60 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6594
56 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6635
52 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6676
48 offset
NFS lookup tftpboot\Default\proc
NFS lookup tftpboot\Default\sbin
NFS lookup C:\Program Files\rioboot\tftpboot\Default\sbin\test
NFS lookup C:\Program Files\rioboot\tftpboot\Default\bin\sh
NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\ld-linux.so.2
NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.preload
NFS lookup C:\Program Files\rioboot\tftpboot\Default\sbin\riot
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 0 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 458752 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 462848 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 466944 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 471040 o
ffset
NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte
s 0 offset
s 4096 offset
s 8192 offset
s 12288 offset
s 65536 offset
s 69632 offset
s 73728 offset
s 77824 offset
NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 0 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 4096
offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 8192
offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1228
8 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1474
56 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1515
52 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1556
48 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1597
44 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1638
4 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2048
0 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2457
6 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2867
2 offset
s 49152 offset
s 53248 offset
s 57344 offset
s 61440 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1146
88 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1187
84 offset
80 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1269
76 offset
s 16384 offset
s 20480 offset
s 24576 offset
s 28672 offset
s 32768 offset
s 36864 offset
s 40960 offset
s 45056 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 4096 off
set
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 8192 off
set
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 12288 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 262144 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 266240 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 270336 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 274432 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 65536 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 69632 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 73728 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 77824 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 278528 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 282624 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 286720 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 290816 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 16384 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 20480 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 24576 of
fset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 28672 of
fset
NFS lookup C:\Program Files\rioboot\tftpboot\Default\dev\display
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 327680 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 331776 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 335872 o
ffset
NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 339968 o
ffset
#248586 - 08/02/2005 02:10 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: rembrandt]
rembrandt
i should also note ..
I also tried using ARM/Jrec and trio
I get this error after the rio boots into Trio
SSDP Discovery of jreceiver failed"
in my jrec window i get :
5453 [RioStatusDaemon] WARN status.RioStatusDaemon - socket problem with rio st
atus
java.net.BindException: Address already in use: Cannot bind
at java.net.PlainDatagramSocketImpl.bind(Native Method)
at java.net.DatagramSocket.bind(Unknown Source)
at java.net.DatagramSocket.<init>(Unknown Source)
at jreceiver.client.rio.status.RioStatusDaemon.doWork(RioStatusDaemon.ja
va:229)
at jreceiver.util.Daemon$1.run(Daemon.java:94)
at java.lang.Thread.run(Unknown Source)
5547 [RioSSDP] ERROR status.RioSSDP - unrecoverable IO problem, stopping worker
at jreceiver.client.rio.status.RioSSDP$1.run(RioSSDP.java:153)
I get this when i try to request music lists to queue
#248587 - 08/02/2005 12:01 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: rembrandt]
drule
Regarding the SSDP discovery of jreceiver error. Did you remember to install the jreceiver-rio-0.2.5 component? The install instructions are near the bottom of the JReceiver: Rio Install page and are easily missed.
Dave
#248588 - 08/02/2005 12:11 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: drule]
rembrandt
yeah
turns out the arm/jrec/trio error was an ip conflict (somehow)
in my conf file for jrec i changed the references that were localhost:8080 to the actual ip of the box .. and that stopped the arm/jrec errors.
haven't had the courage to get back at rioboot :P but the day is still young
#248589 - 16/02/2005 02:11 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: drule]
justDave
I use gnu tar myself. It recreates the symlinks, though neither Windows nor Java understands them - at least they're easy to track down with "find" or whatever.
No, no, no...
/proc/kcore isn't really a file. It's a view of the ram on the current system. It only exists at runtime. Since I couldn't symlink to it, I just left /dev/core out. I haven't noticed a problem.
If there were a problem, it wouldn't be solved by copying a ram snapshot off a LInux box anyway.
As for all the busybox copies, I suspect riot doesn't use most of them either. Might be worth narrowing it down a bit to save space - all those copies do add up. I haven't bothered since it doesn't really hurt anything.
Problem solved?
I used to post these periodically but I've gotten lazy. I'm still running a post 1.5 beta myself - not something I should share. I'll post one if I ever catch up with the current release and there's still a need but if you have one handy you should definitely go for it.
#248590 - 16/02/2005 12:38 Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots [Re: justDave]
drule
Problem solved indeed. Thanks for the info on /proc/kcore. Us Linux newbies learn something new everyday. I will zip up a RioBoot version of tRio 1.6 and make it available.
-DR
