#249074 - 12/02/2005 20:55 Playing wav files from right click menu?
newguy1
Loc: Massachusetts,USA
If I right click on a wave file,there is an option to" play this wave file" when I do that the file plays but there is no way to control it.There is no player that actually opens up.
How is the file playing?
MIKE 80Gb RIO
#249075 - 12/02/2005 22:22 Re: Playing wav files from right click menu? [Re: newguy1]
I assume Explorer can play wavs. If you want controls, install or define another app to be the default.
#249076 - 12/02/2005 22:26 Re: Playing wav files from right click menu? [Re: newguy1]
As Bruno said, you can associate another player with the filetype, such as WinAmp. That's done in WinAmp's options.
But if Explorer is the one playing the file, and if you are in windows XP, there is a control bar on the left pane of the explorer window I think. Somewhere.
It's possible you have that bar or that whole windowpane disabled on your system. Look around the explorer menus for an option to turn it back on again.
#249077 - 12/02/2005 23:00 Re: Playing wav files from right click menu? [Re: tfabris]
newguy1
I use windows 2000
There is the control bar in the explorer window but that is not playing the file because while the file is playing with the "unknown" player I can play it with that control bar,
MIKE 80Gb RIO
#249078 - 12/02/2005 23:08 Re: Playing wav files from right click menu? [Re: newguy1]
newguy1
The weird thing is also that task manager shows no difference when the file plays this way but it does if i play it with winamp or mediaplayer
MIKE 80Gb RIO
#249079 - 13/02/2005 02:10 Re: Playing wav files from right click menu? [Re: newguy1]
SE_Sport_Driver
I bet it'll show up in Processes rather than Applications.
This sounds like one of those things integrated into Windows, just like Explorer. Just like when you're adjusting your sound profile in the Control Panel and are previewing sounds, it's Explorer (probably with some Windows Media Player built in) that is playing the sounds.
Are you just curious about this? If it's annoying, you put a check next to ".wav" for file type association in Winamp.
#249080 - 13/02/2005 03:39 Re: Playing wav files from right click menu? [Re: newguy1]
SonicSnoop
Loc: Triangle, VA
Should be able to press and hold the shift key down and right click on the file and select Open With... and choose your audio program through that window and just check that check box to always use that program.
#249081 - 13/02/2005 12:03 Re: Playing wav files from right click menu? [Re: SE_Sport_Driver]
newguy1
Yes I'm just curious.
If I left click the wave files they open in winamp just fine,it's when I right click and select the option to play this wave file from the menu that i'm curious about.(see attachnent in 1st post)
It does not show up in processes.
MIKE 80Gb RIO
#249082 - 14/02/2005 18:33 Re: Playing wav files from right click menu? [Re: newguy1]
You should be able to open the "File Types" menu and see what action that context-menu item is related to.
#249083 - 15/02/2005 02:04 Re: Playing wav files from right click menu? [Re: wfaulk]
newguy1
The only choices for wave are open and play.
The other choices aren't listed there but they are in the right click menu.
see attachment
Edited by newguy1 (15/02/2005 02:04)
MIKE 80Gb RIO
