#249878 - 18/02/2005 19:58 Successive queuing on the Karma
SSR
Loc: Sao Paulo, Brazil
Hi folks,
Maybe I'm missing something here, but what I would like to do is to be able to queue various albums from the Music Library *without* having to leave it.
Currently I select the album, hit the right joystick button, then it takes me back to the queue. I often want to stay in the library and queue another album from the same artist, or someone else closeby. With my Creative Labs player there's an option called "add to selected" where it adds to the queue, but doesn't take you back to the queue and you stay at the same point in the library.
Did Rio really not design it similarly? Which is why I think I must be missing something...
TIA
http://www.stainlesssteelrat.net
#249879 - 19/02/2005 19:10 Re: Successive queuing on the Karma [Re: SSR]
As with the car player, I *think* a long press on Play Music will take you straight to the last leaf node you selected. I don't have my Karma here to confirm that though.
#249880 - 20/02/2005 00:32 Re: Successive queuing on the Karma [Re: rob]
You are correct and it like the car player even remembers the last place after a reboot.
#249881 - 20/02/2005 00:36 Re: Successive queuing on the Karma [Re: msaeger]
No actually that is wrong opps. That works if you go to the main menu but if you hold in the scroll wheel to get to the insert, append, reorder menu it dosen't.
#249882 - 20/02/2005 13:17 Re: Successive queuing on the Karma [Re: msaeger]
SSR
Sorry guys, and silly question, but what's the "Play Music" button?
I've tried the "play" button i.e. up on the joystick and a couple of others, but no joy.
#249883 - 20/02/2005 13:29 Re: Successive queuing on the Karma [Re: SSR]
I think he means the "Play Music" menu item.
#249884 - 20/02/2005 14:20 Re: Successive queuing on the Karma [Re: tfabris]
If you press menu the first item on the list is "play music" if you hold the menu button with that selected it goes to the last place you played something at. The problem is there is unlike the empeg there is no way to add it to the playlist from there.
#249885 - 20/02/2005 19:57 Re: Successive queuing on the Karma [Re: msaeger]
SSR
Great! Thanks guys, that solves a few extra joystick clicks
