#250867 - 02/03/2005 21:26 Reboot Empeg via Telnet
kendrick
How can you reboot the empeg via telnet.
When i try to run reboot -n it says
Could not determine runlevel - doing softreboot
#250868 - 02/03/2005 21:58 Re: Reboot Empeg via Telnet [Re: kendrick]
pim
reboot -f
Pim
#250869 - 02/03/2005 22:02 Re: Reboot Empeg via Telnet [Re: pim]
kendrick
Gracias
scripts are finally complete Thanks.
#250870 - 02/03/2005 22:11 Re: Reboot Empeg via Telnet [Re: kendrick]
pim
Oh, make sure your drives are mounted ro before you reboot -f,
otherwise you''l need to fsck the drives.
Pim
#250871 - 06/03/2005 05:49 Re: Reboot Empeg via Telnet [Re: pim]
ajayrockrock
Loc: Riverside, CA
I have a semi-related question... how do you quit the player software from telnet? If you boot up serial, you can just hit 'q' and it drops you into the shell. And if I kill -15 <player_pid> it just restarts. I'm using rsync on my player and right now and I have to hook it up via ethernet and a serial connection just to sync up. It would be nice to not have to bother with minicom anymore and just use telnet for everything.
Thanks,
Ajay
#250872 - 06/03/2005 18:15 Re: Reboot Empeg via Telnet [Re: ajayrockrock]
Loc: Los Angeles, CA
kill -2
#250873 - 06/03/2005 18:56 Re: Reboot Empeg via Telnet [Re: image]
pim
If you have killall, killall -HUP bash will do nicely.
Pim
