#25093 - 18/01/2001 04:34 "Nokia" type menu navigation
Dava
Loc: Bucks UK
I like the way that you can use the remote's number pad to select a menu option directly but I would prefer it if it entered that option aswell rather than having to press the OK button between each selection. i.e
Current method to select EQ is
9
DNPP
5
DNPP
Would be easier with:
9
5
Just Like on a Nokia phone. What think ye??
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#25094 - 18/01/2001 08:28 Re: "Nokia" type menu navigation [Re: Dava]
94cobra
Sound like it would be possible. If using the numbers to select it could automatically enter that choice. Would take some time to learn to get it right, but I think I would like.
Proud Owner of MK2 080000558 - 18gb Blue
Sonic Blue 03 Cobra Vert Owner!!!
#25095 - 18/01/2001 10:22 Re: "Nokia" type menu navigation [Re: 94cobra]
My only problem with this is that sometimes the menu order changes with certain software releases, and I'd be up a creek in that case.
Users can also make certain menu items "visible" themselves (for example, it's possible to add a "quit" menu item to the player if you've got something going on in a shell script). So that's another way that the menu order can change.
I also foresee a future where plug-ins will add their own menu items.
#25096 - 18/01/2001 11:07 Re: "Nokia" type menu navigation [Re: tfabris]
Smoker_Man
Loc: Calgary, CANADA
Oh all knowledgable oracle, please impart on us some of your knowledge... just when is this future going to fall apon us?
That aint a half bad idea, I was wondering if there was a setting toggle somewhere where you could navigate through the menu "Nokia style".
Smoker_Man
#080000449 MkII - 36Gb Blue
2x160Gb MkII Lighted Buttons 080000449
#25097 - 22/01/2001 08:02 Re: "Nokia" type menu navigation [Re: tfabris]
Dava
Loc: Bucks UK
I can understand that they may change but this would still be the case with the current procedure. All I want is the software to go that extra step and press OK for me aswell. It would make sense to have all the common items (Sound, Power off etc) to be the first set of items on the menu. Then the addins can be later on (probably above 9 anyway). I think that many people will use the left/right or volume wheel to select anyway.
In any case it would not take long to learn the number for a particular option after each upgrade.
#25098 - 22/01/2001 21:29 Re: "Nokia" type menu navigation [Re: Dava]
I've had nokia phones, for me that system didn't help much. I just didn't need to go down the menus often enough to learn the numbers.
-- Glenn
#25099 - 30/01/2001 02:44 Re: "Nokia" type menu navigation [Re: gbeer]
Tino
Loc: The Netherlands
I also have a nokia phone and this is an excellent way to quickly get to the menu option you use often.
Of course i don't know all the menu item numbers, but the ones i use often are quickly learned and this shortcut works excellent...
Tino
