#251500 - 12/03/2005 08:57 player rebooting
ukengb
Loc: United Kingdom
I've been messing about with the database files (not important why right now) and now when I try to reboot the empeg the player app continually restarts.
The trouble is that I cannot now do anything with the empeg. I have Hyperterminal connected and can see all the serial output, but I cannot stop the player from re-loading. Pressing q simply doesn't do anything. The keypress IS recognised as it appears on screen, but it doesn't stop the player.
CNTRL-T performs the RAM test OK.
I just need to stop the player so I can access the files and fix the problem. Isn't there someway to boot the empeg but NOT start the player app?
Failing that I can only think I have to re-flash the OEM Developer image and then re-install Hijack (sigh). Surely there's a better way?
#251501 - 12/03/2005 09:33 Re: player rebooting [Re: ukengb]
ukengb
Loc: United Kingdom
OK, I've figured how to use CTRL-C to halt the player on bootup (did try it bofore, but didn't seem to work). But I deleted the databases and the player still crashes with a 'segmentation fault'. I suspect this is my fault as I re-booted the player while still in rw mode - my fault, too much late night scripting.
So, I'll re-flash with a new image, but while I have seen mention of a 2.01 final, I can only find 2.00. From where can I download 2.01?
#251502 - 12/03/2005 09:39 Re: player rebooting [Re: ukengb]
AudunE
Loc: Trondheim, Norway
2.01 is only useful if you have added extra memory to the Empeg, but you will find it here: http://www.empeg.com/v3alpha/
- Audun E -
#251503 - 12/03/2005 12:45 Re: player rebooting [Re: ukengb]
the player app continually restarts. The trouble is that I cannot now do anything with the empeg.
There is a command to get the player to restart an empty playlist here, and there is a command to manually fix the databases here.
One of those or perhaps a combination of both will get you back into a bootable state with the player. Please note that you might also have messed up your filesystem, too.
#251504 - 15/03/2005 16:46 Re: player rebooting [Re: ukengb]
ukengb
Loc: United Kingdom
It's happened again. Something has got screwed up and it won't reboot cleanly.
Once I'd unmounted the second drive and fsck'd / and /drive0 it is now happy again and the player starts ok, but I cannot fsck /dev/hdc4. I just get the following error:-
no room for private writable mapping
error: -12
fsck.ext2: Memory allocation failed while retrying to read bitmaps for /dev/hdc
Any suggestions as to what has happened here and how to correct it?
Is there a binary available to enable me to format a single specified drive, so I don't have to start from scratch again or delve into the hardware in order to disconnect a drive each time?
#251505 - 15/03/2005 17:00 Re: player rebooting [Re: ukengb]
Did you enable swap?
#251506 - 15/03/2005 17:08 Re: player rebooting [Re: tman]
ukengb
Loc: United Kingdom
Yes. Does that indicate a possible fix?
#251507 - 16/03/2005 07:32 Re: player rebooting [Re: ukengb]
http://www.differentpla.net/node/view/199
http://www.differentpla.net/node/view/200
#251508 - 16/03/2005 12:24 Re: player rebooting [Re: Roger]
ukengb
Loc: United Kingdom
Is mke2fs on there already? Damn, how did I miss that. Thanks Rog.
I have another problem, but I think it warrants a new topic.
